It is currently Sat Jul 19, 2025 11:52 pm
PostPosted: Sun Jun 18, 2017 5:04 pm
Have a problem at higher revs where gauges seem inaccurate- Fuel level can drop from 1/2 tank to 1/4 tank full. I have tested the output of the voltage regulator with the ignition on and it is 9.97 volts. Anyone know what the problem maybe? Should I purchase a new voltage regulator?
Thanks, Scott.
PostPosted: Sun Jun 18, 2017 5:10 pm
Does the voltage change when you rev the engine?
PostPosted: Sun Jun 18, 2017 5:26 pm
haven,t checked it under higher revs. i'll have to check it.
PostPosted: Sun Jun 18, 2017 5:49 pm
Body vibration. They use a vibrating bimetallic strip.
I cured mine by replacing with an electronic one. Thanks wombat. ;)
PostPosted: Sun Jun 18, 2017 5:55 pm
Minis are smooth as silk..... LOL
PostPosted: Sun Jun 18, 2017 6:47 pm
How do you get hold of an electronic voltage regulator? Can you place it inside the standard casing so that it looks stock?
PostPosted: Sun Jun 18, 2017 8:06 pm
Thanks for all your replies. i'll checkout jaycar tomorrow and see if I can a 3 pin ic voltage regulator and make something up.
PostPosted: Sun Jun 18, 2017 8:08 pm
Yes, you can. I can refer you to a set of instructions with details of the device that you need to buy to fit inside the case.
http://www.britishv8.org/articles/mgb-v ... ilizer.htm
I used the LM2940T-10.0
PostPosted: Sun Jun 18, 2017 8:58 pm
David, thanks so much for that info, much appreciated
PostPosted: Mon Jun 19, 2017 2:40 pm
Bad earth
Users browsing this forum: No registered users and 70 guests
