It is currently Sat Jul 19, 2025 11:55 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2, 3  Next
 Post subject: Morris 1100S
PostPosted: Mon Jun 12, 2017 5:31 pm
Hi guys,
Does anyone know if a Morris 1100s motor will fit in a mini?
Zulu
Zulu...
1967 mini Cooper S
 Post subject: Re: Morris 1100S
PostPosted: Mon Jun 12, 2017 5:43 pm
Yes..with a few minor changes including a change of diff...
Cheers, Ian
PostPosted: Mon Jun 12, 2017 6:24 pm
trim the front engine plate { front engine mount in morrie 1100} check the diff ratio, std 1100 is 4.2ish {I think} the gearbox extension housing is different to a mini one, slightly longer and has a sandwich plate { not a tasty treat} between box and shift housing. stick a mini radiator and shroud on it and welcome to the big bore club.
PostPosted: Tue Jun 13, 2017 1:24 pm
silly question this... but how much do you need to trim off?
Zulu...
1967 mini Cooper S
PostPosted: Tue Jun 13, 2017 3:36 pm
Cut the mount brackets off, or trim it to Mini shape. Use oxy or angle grinder.
It's just for clearance.
PostPosted: Tue Jun 13, 2017 6:19 pm
If you keep the 1100S diff housing make sure you get the remote gear change linkage too from the 1100 as it bolts to the diff housing differently to a Mini one due to the rubber sandwich plate. I have this in my van and it works fine.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Tue Jun 13, 2017 6:34 pm
Re the rubber sandwich plate, you can burn the rubber out and weld a steel strip in between to make it solid. Like Mini remote feel then.
PostPosted: Tue Jun 13, 2017 8:58 pm
Such great info Dr Mini.
What would the benefits be of the 1100 S motor over a mini 1275?
Zulu...
1967 mini Cooper S
PostPosted: Tue Jun 13, 2017 9:19 pm
Morris 1100S motor is much the same as any other non S 1275.
But note the gearbox is only 3 synchro, and parts are getting scarcer for these.
Most people put the 1100S onto a Mini K remote box, or a rodchange one. Both are 4 synchro.
PostPosted: Tue Jun 13, 2017 9:54 pm
there is no difference, therefore no other benefit. They're cheap and easier to get cos there were a lot more of them made.... If you can buy one, buy it...
I've had an 1100S motor in my cars since 1995 - I say cars because I've moved the same motor from car to car, and I say the same motor because it's the same crank, but I think I've had 4 different blocks
PostPosted: Wed Jun 14, 2017 2:35 pm
No sideplates in an 1100S. One less place to leak!
Also, are they only a 9 stud head not 11 stud?
PostPosted: Wed Jun 14, 2017 3:55 pm
well, yeah, but only S motors had an 11 stud head standard, 1275LS, Californian Mokes, Rovers etc. had 9 stud heads
but that doesn't matter one little bit, and it can easily be changed with a drill...
PostPosted: Wed Jun 14, 2017 4:06 pm
I'm thinking it will go on a mini K with the manual rod changer box.
Zulu...
1967 mini Cooper S
PostPosted: Thu Jun 15, 2017 12:32 pm
I have an 1100S on a 22G1128 (4 synchro) box.
I changed the original 4.13:1 diff for a 2.95:1 and it is now an amazing highway cruising machine, but still has reasonable acceleration.
PostPosted: Thu Jun 15, 2017 8:23 pm
I love it Phil. Thanks!
Zulu...
1967 mini Cooper S
Users browsing this forum: Bing [Bot] and 77 guests
