It is currently Sun Jul 20, 2025 12:15 pm
PostPosted: Fri Jun 09, 2017 10:53 am
What is the correct CV inner joint setup for the Mk1 Cooper S?
My car looks like it has standard universal joints like: http://www.classicmotoring.net.au/cmos/ ... ts_id=1645
But then I read the description and it states "Except for Cooper S"
PostPosted: Fri Jun 09, 2017 11:18 am
Hardy Spicer joints were an option on early Cooper S not Std fitment. Their were Cooper S specific doughnuts Originally but were superseded to one type.
PostPosted: Fri Jun 09, 2017 11:20 am
The ones you linked are an aftermarket replacement for the original rubber cross joints.
Original
http://www.classicmotoring.net.au/cmos/ ... cts_id=107
PostPosted: Fri Jun 09, 2017 11:21 am
Thanks for the quick reply, that makes me feel a bit better, I was starting to think it was for sure meant to have the hardy spicer units and had been converted for what ever reason.
A somewhat embarrassing question now... are the universal joints supposed to have a rubber boot to protect them?
PostPosted: Fri Jun 09, 2017 11:23 am
Original
Yes I realize that, but in the description for either it states "Except Cooper S"
PostPosted: Fri Jun 09, 2017 12:00 pm
I believe they went to Hardy Spicer in 1966. Std not optional.
Shaft splines are the same so either fits.
PostPosted: Fri Jun 09, 2017 12:47 pm
Early ..ie 63/64 etc Cooper Ss (UK built cars) had the "normal" Mini rubber cross type joint.
The original link is for the aftermarket item that could be used as a direct replacement for the standard (i.e. factory) rubber joint.
Later (don't know exact changeover point) - but I think including Aus built Ss used the metal Hardy Spicer joint.... and its associated fittings.
The link is to an Australian company that doesn't seem to appreciate that their comment is not completely correct...but may be so for Aus built cars.
Cheers, Ian
PostPosted: Fri Jun 09, 2017 1:07 pm
I have the changeover listed as engine 9FSAY 41234. But i dont know where that info came from.
PostPosted: Fri Jun 09, 2017 1:30 pm
Oh :( Looks like my car got changed over at some stage then.
Should the rubber X style uni joints still have a boot to protect them?
PostPosted: Fri Jun 09, 2017 3:00 pm
I believe none of the uni joints ever had a protector boot, only the CV joint.
I also thought all Australian assembled Cooper S had the Hardie Spicer joint, not the rubber uni, but happy to be corrected.
In case it helps here's the relevant pages from the Mini parts catalogue PUB1012.
PostPosted: Fri Jun 09, 2017 3:35 pm
This is where i got the 9FSAY 41234 changeover from. A few of the mini websites are also using the same info. Gearbox ID's http://mk1-performance-conversions.co.uk/gearboxes.pdf
PostPosted: Fri Jun 09, 2017 3:44 pm
I wonder what Uni joints the S ran at Bathurst in '66?
PostPosted: Fri Jun 09, 2017 3:57 pm
I asked the previous owner of my car (he bought it new) and he says it has not been changed, that's how he got it new (with the rubber joint).
Wonder what the story is with my car (46388)?
PostPosted: Fri Jun 09, 2017 4:10 pm
It does seem very late to have rubber unis. I think you would be hard pressed to find another 1967 car with rubber unis.
PostPosted: Fri Jun 09, 2017 10:59 pm
My first S, registered in July 66 - car YKG2S2 1090 - engine No 9FSaY 39922, had the rubber inner unis and I had to replace the LH one several times over the 60K+kms that I had the car.
It was a real PIA job to replace it without splitting the front suspension ball joints and removing the drive shaft.
These also had the small vertical oil cooler and, IIRC, blue coloured displacers.
I'm not sure but I think the 66 Bathurst cars used the Hardy Spicer inner unis and the large horizontal oil cooler.
RonR
68 build Mk1 Cooper S
Users browsing this forum: No registered users and 64 guests
