It is currently Sun Jul 20, 2025 12:06 pm
 Post subject: Fuel tank brackets
PostPosted: Tue Jun 06, 2017 12:42 pm
Hi all,
I'm getting ready to put the tank bottom bracket and strap in my car for the RH tank. I noticed the strap has some cork on it to avoid damage to the tank. Was it fitted to the bottom bracket too? Is the cork still available or is there a better option?
Also, what is the best way to attach the bottom bracket to the boot floor? I'm guessing rivet it on as the access from below is non-existent?
 Post subject: Re: Fuel tank brackets
PostPosted: Tue Jun 06, 2017 12:55 pm
Mine had felt stuck on to the straps and the lower bracket, but mine was dealer installed not factory. The lower support bracket was pop riveted on.
PostPosted: Tue Jun 06, 2017 1:58 pm
Thanks, felt would be a good option too. Looks like Bunnings does adhesive sheets of both
Cork
https://www.bunnings.com.au/boyle-1-5m- ... m_p1662549
Felt
https://www.bunnings.com.au/surface-gar ... k_p3970368
PostPosted: Tue Jun 06, 2017 2:10 pm
Just checked my NOS straps and lower bracket on project car.
Straps have cork on both upper and lower straps, bracket is spot welded.
:D
1970 Mk2
1968 Mk1 project
PostPosted: Tue Jun 06, 2017 2:19 pm
Riv-nuts or maybe a plugweld, but not knowing how good the sheet below is, might be better to go the riv-nuts or rivets.
Nick
PostPosted: Tue Jun 06, 2017 2:51 pm
Thanks guys. Riveting will be the best option then (I don't have a welder) and I'll have a look at the cork
PostPosted: Tue Jun 06, 2017 8:22 pm
timmy201 wrote:
Hi all,
Both my '66 and 70 Ss had cork inside top and bottom straps. Recently, I bought a roll of cork gasket material from local parts shop and cut to size. Glued with contact adhesive.
Maybe felt will hold condensation from the tank - cork less absorbent?
When you say "bottom bracket" - do you mean the bracket the tank sits on or the bottom strap for the tank?
The tank stand was sometimes pop-riveted.
In my '66 S, the bottom strap bolts on through the floor and is accessible from underneath for a nut. Later Ss used a captive nut like the LH tank
PostPosted: Tue Jun 06, 2017 8:34 pm
I've attached images of my Aussie production bracket and anchor plate. The plate has a slight fold mid length, maybe just to secure before bracket is attached. Also painted black.
Images aren't attaching.............PM me with your email and I'll send them if you want.
1970 Mk2
1968 Mk1 project
PostPosted: Tue Jun 06, 2017 10:32 pm
Mine uses a block of wood. It's been in there 20 years now, works fine. :)
