It is currently Sun Jul 20, 2025 8:01 am
PostPosted: Sun Jun 04, 2017 2:49 pm
Hi all,
I was driving my mini a few months back and when taking off from a light i lost all power to the wheels (engine still running). While towing it home it made a rather loud grinding noise. I have since started it and tried all the gears, they engage fine and as i work through the gears the grinding noise gets faster. This has led me to believe that i broke my diff.
I have pulled the engine out of the car and slowly taken parts of to check what the issue is. So far everything seems as is should, diff seems to be in working order no visible damage, split the gearbox and it also seems in good condition. There was nothing in the oil.
I have no idea on what to do next other then to get the gearbox from my spare(parts only) engine.
Any thoughts on what could be wrong? anyone else suffered this?
Thomas
PostPosted: Sun Jun 04, 2017 3:03 pm
driveshaft didn't come out of the CV?
Broken inboard CV cage?
my two cents
PostPosted: Sun Jun 04, 2017 3:06 pm
Nothing i can fault on the cv's. driveshafts were in place.
PostPosted: Sun Jun 04, 2017 6:01 pm
Take some pics of bits and post them. Will be much easier to help then :)
PostPosted: Sun Jun 04, 2017 6:09 pm
it's gotta be on the output side of the gearbox - 3rd motion shaft or diff...
engage 4th gear (fastest), get someone to hold on to the diff outputs (stop them from turning) and turn the input shaft
PostPosted: Sun Jun 04, 2017 6:25 pm
Clutch?
PostPosted: Sun Jun 04, 2017 9:35 pm
Pinion nut on output shaft, may have come loose?
Why is it the things that make me tick, are also the things that make me go boom?
Users browsing this forum: No registered users and 65 guests
