It is currently Sun Jul 20, 2025 4:21 am
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue May 23, 2017 1:29 pm
Docs right i have had that too my 2 cases i was loosing water
PostPosted: Tue May 23, 2017 4:18 pm
So goldbracade you fixed it with a pcv? How do you hook these up? I haven't used one before
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Tue May 23, 2017 5:39 pm
I hooked mine up like a cooper s off inlet manifold to bottom of pcv top side to crankcase no breather in rocker cover but you need the filler cap that suits that system too
PostPosted: Tue May 23, 2017 9:31 pm
I have one of those water heated single 1.5 Su manifolds. It does have a threaded hole in it with a grub screw in it could I use this for a pcv valve? Can I have a pic?
1970 mini k
1975 leyland
PostPosted: Wed May 24, 2017 6:37 am
Yes you can screw a fitting in there for a PCV valve. But if your SU has a vacuum port on the side, I'd use that instead, no valve required. Simple but works. Was used on Clubman 1275LS also late 998.
PostPosted: Wed May 24, 2017 12:08 pm
Ok so now for a pcv valve. Any you can show me to buy on eBay or something doc?
1970 mini k
1975 leyland
PostPosted: Wed May 24, 2017 6:47 pm
Google PCV 13.
http://www.eziautoparts.com.au/pcv-valve-pcv-013.html
Or use the big Smiths Cooper S, and Morris 1100S one.
Last edited by drmini in aust on Sun May 28, 2017 7:57 am, edited 1 time in total.
PostPosted: Fri May 26, 2017 8:18 pm
You mention that you lose some water from the radiator. Do you mean that if you don't top it up, it will eventually empty itself, or that after topping it up and going for a drive, the coolant level drops?
If you don't have an overflow the coolant level will drop after a heat cycle - and then stay at that level, provided all is good. I agree with the doc to check that it's not regular condensation - take it out for a long drive and see if it clears it up. You can also check if the coolant is dropping past normal at the same time.
You also mention it's running cold - what are you using to measure that temperature? Most mini gauges are at best an indication.
PostPosted: Fri May 26, 2017 10:08 pm
G'day irish, I have a capillary gauge installed and it reads at approximately 65 degrees when warm. I leave for work at 5 in the morning and being cold this time of year it won't even get up to 60. The condensation doesn't clear up as it's a 50 min drive and it's still the same. However it was a little low on water the other ay and running at 180 which is like 82 degrees I think and there was basically no condensation from this run however it has started to blow a little oil out the breather so I'm thinking the mechanic that put my cam bearings in has installed them wrong so will have to put a feeler gauge with a hole in it under number one rocker to reduce the oil flow.
1970 mini k
1975 leyland
PostPosted: Sat May 27, 2017 9:07 am
Could be just normal thermo-syphoning coolant loss from the type of running its doing...fit an overflow tank if it don't already have one :idea:
PostPosted: Sat May 27, 2017 12:40 pm
I believe the normal symptom of cam bearing upside down is the rocker cover filling with oil and pouring out of the oil filler cap... I think you'd have noticed that by now
PostPosted: Sat May 27, 2017 6:29 pm
Yea that's what I was thinking Simon. I do have oil that somehow gets all over the top of my rocker cover I have driven then hopped out and seen whether or not it is full of oil but it's not. What else could cause this?
1970 mini k
1975 leyland
PostPosted: Sat May 27, 2017 6:39 pm
Rocker Cover Gasket!
PostPosted: Sat May 27, 2017 8:58 pm
But I also have a hose on my breather into a bottle and have started the last couple of longer drives to get oil in there. The same reason I knew of the condensation.
1970 mini k
1975 leyland
PostPosted: Sun May 28, 2017 1:02 pm
Side Plate Gaskets
Users browsing this forum: No registered users and 69 guests
