It is currently Sun Jul 20, 2025 8:11 am
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
 Post subject: Any idea? Head gasket?
PostPosted: Mon May 22, 2017 6:13 pm
G'day guys and girls hope you are well! I have a dilemma my newly built motor blows condensation out the breather. I have a hose connected to the breather into a bottle and it slowly catches whitish watery stuff which I assume is a mix of mostly water and a little oil. I also lose water from my radiator. I have compression on all cylinders and the car is running fine. No oil in water or water in oil or water out the exhaust. What's your thoughts?
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Mon May 22, 2017 6:44 pm
What size motor
PostPosted: Mon May 22, 2017 6:54 pm
1275 1100s motor
1970 mini k
1975 leyland
PostPosted: Mon May 22, 2017 7:15 pm
Not saying this is the problem but i have had a couple of 1275's done similar and it was in the head the brass plugs in the head face one was loose in each case I replaced them and all was good
PostPosted: Mon May 22, 2017 7:26 pm
What do you mean the brass plugs on the face of the head? You mean the anti pollution heads? If so this head isn't one of those. If not can you explain a bit more cause I don't understand. Cheers
1970 mini k
1975 leyland
PostPosted: Mon May 22, 2017 7:39 pm
I'm assuming GB'62 is referring to the brass inserts in the face of the head (for the cooling system).
How new is newly built? They tend to have a bit more blow-by until the rings properly bed in.
PostPosted: Mon May 22, 2017 7:46 pm
Done approximately 2000kms. Sorry I'm still confused where these brass plugs are? Do you have a pic??? Are they hard or easy to replace?
1970 mini k
1975 leyland
PostPosted: Mon May 22, 2017 8:08 pm
No pic on me... You would have to remove the head to look at them as they are pressed into the face (the part in contact with the block).
PostPosted: Mon May 22, 2017 8:14 pm
The shiney yellow things.Image
PostPosted: Mon May 22, 2017 8:16 pm
just take the head off....
PostPosted: Mon May 22, 2017 8:26 pm
That's the plug s
PostPosted: Mon May 22, 2017 8:52 pm
Ah yea I understand now. Are they hard to replace or expensive to replace? How do you know if they're no good and need replacing?
1970 mini k
1975 leyland
PostPosted: Mon May 22, 2017 10:56 pm
Is it actually loosing coolant? Could just be atmospheric condensation
PostPosted: Tue May 23, 2017 6:50 am
Ever litre of fuel burnt creates over a litre of water vapour. Some gets past the rings. If engine is running cold or doing short runs, water vapour condenses on the coldest parts of the motor. Eg rocker cover and breathers. Called 'mayo'.
It is very common on engines with poorly designed crankcase ventilation, like Mini deluxe and Mini K. If a PCV system is fitted, it doesn't happen.
I would first check running temp and thermostat before ripping the head off.
PostPosted: Tue May 23, 2017 1:22 pm
Playboy doc that's worth a mention as my car is running cool. I think too cool. Runs 60 or less degrees sometimes will nearly reach 70 but soon comes back down. I changed the thermostat as the one in it wasn't working but is doing the same thing still-running cold.
1970 mini k
1975 leyland
