It is currently Sun Jul 20, 2025 12:59 pm
 Post subject: HIF 44 / HS6
PostPosted: Sat May 13, 2017 6:01 pm
Fitted a New GR Manifold to my mini today, tried both HIF44 and HS6 both cleared
without any problems and room to fit an K&N offset air filter or ramtube, the difference over the twin 1 1/4 Su's was mind blowing, could not believe the difference in power and acceleration.
Seems like it's a completely different Car.
here are some pics HS6 is on a mates car HIF is on mine . Very Happy :D
A HUGE THANKYOU TO GRAHAM RUSSELL
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
 Post subject: Re: HIF 44 / HS6
PostPosted: Sat May 13, 2017 6:16 pm
With a Minispares C-AHT770 manifold my HIF44 fits with enough room for the K&N semi-conical filter to fit forward of the firewall blanket.
Just love my setup.
PostPosted: Sun May 14, 2017 6:54 pm
Oh dear, worry, worry...
Hi David
Yes the Mini Spares does fit with more room and I tell a lot of people to fit them, but I now have had them CNC machined and they fit a lot better plus they are a lot cheaper than mine, now if you want performance my manifold will run rings around any other manifold on the market, and the more the motor is modified the more HP they will make over the other manifolds so it depends what you want go or show and yes you can still fit the mat in you just have to do bit of fiddle :D
Graham Russell
PostPosted: Mon May 15, 2017 6:53 pm
Does it fit with a centre speedo?
WD40'll fix it!
If it don't, use a big hammer!
PostPosted: Mon May 15, 2017 10:07 pm
Yes , centre speedo in a 1969 round nose
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
PostPosted: Mon May 15, 2017 10:50 pm
Awesome, thanks Marl.
WD40'll fix it!
PostPosted: Tue May 16, 2017 2:57 pm
I have a ex-Matic with the GR manifold and HS6. I had too machine the manifold faces at the head and carb as well as modifying the firewall to gain enough room, even then I still can't use the choke.
What kind of engine stabilisers does the above HS6 use?
PostPosted: Tue May 16, 2017 4:16 pm
What needle are you running in the HS 6 ?
PostPosted: Tue May 16, 2017 5:50 pm
Bdk
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
PostPosted: Tue May 16, 2017 6:52 pm
OA6
PostPosted: Tue May 16, 2017 7:31 pm
GR wrote:
Hi David
Graham Russell
How much are the new hif44 manifold Graham?
67 Deluxe under going full resto
PostPosted: Wed May 17, 2017 7:22 am
Hi Mattywood
it will set you back $375.
Graham Russell
PostPosted: Wed May 17, 2017 7:40 am
Thanks :D
PostPosted: Thu May 18, 2017 5:37 pm
How does an SU on this GR manifold compare with his Weber 44 IDF conversion? Both seem to have air cleaner clearance issues. I imagine the Weber produces more constant torque throughout the rev range but the SU may match it at lower revs and is more economical?
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
