It is currently Sun Jul 20, 2025 12:24 am
 Post subject: Door skin
PostPosted: Wed May 10, 2017 8:19 pm
Can someone tell me if the round nose door skin is the exact same shape as the clubby, except for the door handle hole? Reason, cut clubby door handle hole out and weld into new door skin.
Dalmeny
 Post subject: Re: Door skin
PostPosted: Wed May 10, 2017 9:00 pm
Some years ago I successfully converted a Clubman door to the early style by cutting out the door latch mechanism and welding in the earlier type as it was the only door I could locate at the time.
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
PostPosted: Thu May 11, 2017 7:50 am
no sorry steve, different shape at the back also
PostPosted: Thu May 11, 2017 12:27 pm
really? there's a difference in the door skin? I thought the frame was different but the skin was the same
PostPosted: Thu May 11, 2017 7:35 pm
Just had a visual of the two side by side.
The door skins look the same, except for the door handle holes.
PostPosted: Fri May 19, 2017 4:04 pm
Just checked with John Smidt, and he has used the round nose skin on a clubby door. Just had to cut the clubby door handle hole into the round nose door skin. I'll just have to give it a try.
Dalmeny
