It is currently Sun Jul 20, 2025 4:54 pm
 Post subject: Pressurising sump
PostPosted: Tue May 09, 2017 5:09 pm
G'day guys and gals I have a question. I have an 1100 s motor (1275) with only one breather on the rocker cover and it has blown through the timing chain cover and pouring out oil like litres within 70km......what Audra this and how can this be fixed? The seal was only on with gasket silicone but it wasn't leaking. So if I put a paper gasket on will it blow it out again? It also blows out condensation on cold morning anyone know why this is???
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
 Post subject: Re: Pressurising sump
PostPosted: Tue May 09, 2017 5:13 pm
I'd start with the proper gasket.
PostPosted: Tue May 09, 2017 5:44 pm
I was thinking that TK I have just had a lot of bad experience with leaking timing chain covers and thought that was a sure way to ensure it wouldn't leak (I know it's rough) should I just try the gasket or gasket and a little bit of gasket silicone?
1970 mini k
1975 leyland
PostPosted: Tue May 09, 2017 7:42 pm
If you have a deeper problem IE: Sump Pressure , it will find the weak point for a leak .
Clean surfaces properly , use paper gasket with silicone either side will be fine and make sure the cover is flat and hasn't been warped.
PostPosted: Tue May 09, 2017 8:17 pm
I also have an 1100S with only one breather from the rocker cover with a hose attached dangling down the back of the engine to atmosphere.
There are absolutely no engine oil leaks.
What is causing the pressurisation that then doesn't escape through the rocker cover vent but forces oil out through the timing cover seal :|
PostPosted: Tue May 09, 2017 8:29 pm
Ok thanks I will try and get to it this week and see how it goes. I'll let you all know
1970 mini k
1975 leyland
PostPosted: Wed May 10, 2017 8:58 am
My 1100s motor has a breather/canister on the idler gear casing! Not sure if it original or not??
PostPosted: Wed May 10, 2017 10:14 am
Original for an 1100S motor.
Users browsing this forum: fuzzy-hair-man and 84 guests
