It is currently Sun Jul 20, 2025 4:21 pm
PostPosted: Sat May 06, 2017 10:56 am
9YaTaH wrote:
Weird...maybe the bottom mounts for a behind-the-grill winter blind? :roll:
Chin spoiler?
Don't think so. They are in the wheel wells.
PostPosted: Sat May 06, 2017 2:03 pm
Yep...maybe front Flood Map mountings...but they are quite high for that...
PostPosted: Sat May 06, 2017 10:06 pm
holes on my car don't match...
PostPosted: Sun May 07, 2017 11:49 pm
Maybe they had a horn mounted on each bracket
a twin horn set up ?, I have seen similar brackets
on minis in that place with horns on them .
I think its a retro fit ,not factory , RVB produced
a twin horn ( high & low pitch ) kit for minis in the 60s.
logical on an 'S' with a cramped engine bay .
I had a mini k with the same brackets in the 70s
PostPosted: Mon May 08, 2017 11:24 am
Thanks for the reply. The car had standard horn/wiring & bracket attached (working). I have owned this car since 1982. The brackets in question don't appear to have had anything attached in any of the 4 holes - no nut/bolt/spring washer marks.
I just have to decide whether to put them back on or bin them.
PostPosted: Mon May 08, 2017 1:31 pm
2. Mounting plates for driving light brackets that slot through the grill?[/quote]
Seems logical.
PostPosted: Mon May 08, 2017 1:56 pm
Seems logical.
The only problem with that is that they are inside the guards and not behind the grille.
