It is currently Wed Jul 23, 2025 1:13 am
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Wed Mar 22, 2017 10:13 am
Will clubman dry front upper control arms on a hydro system affect the front ride height/ clearance of the vehicle?
PostPosted: Thu Mar 23, 2017 6:24 pm
Hi Chris, on one car I found it had a dry upper control arm fitted to the left front, the right side had the correct hydro arm, couldn't get it level or to sit right, particularly left rear, was up in the air. Fixed it by replacing the dry arm for a proper hydro one.
Steve
PostPosted: Thu Mar 23, 2017 7:39 pm
Thanks Steve. Hopefully this will sort my front suspension headache. I knew the car had shocks on the front but presumed the upper control arms were hydro drilled out with the shock bolt attached. On closer inspection I noticed they were clubman.
