It is currently Tue Jul 22, 2025 11:05 am
 Post subject: Light switch qu
PostPosted: Sun Mar 12, 2017 6:16 pm
Am fitting new loom to my moke, have dash all layed out just wondering which colour wire goes to which terminal on the rocker light switch? I have brown, blue, and red. The switch has three terminals, (looking from the back, one by itself on the right and two ( one above tbe other) on the left. Anyone know what goes where, i have the rest sorted.
Steve
 Post subject: Re: Light switch qu
PostPosted: Mon Mar 13, 2017 8:56 am
The back of the switch has numbers on it telling you which wire goes we're look at your wiring diagram it will have the wire going to the certain. Number :) hope this helps
PostPosted: Mon Mar 13, 2017 9:15 am
According to the wiring diagram in the Mini workshop manual:
Brown is the power feed from the fuse block on goes on terminal 3
Red is the side lights output on terminal 2
Blue goes to the dip switch and is on terminal 1
If I were you I'd connect the brown wire first, then use a multimeter to check output on the other switch terminals with the switch in each position.
PostPosted: Tue Mar 14, 2017 12:18 pm
And if you want better lights and switches to last fit and wire some relays. Amen.
"Let us remove your "SHORTS"
Users browsing this forum: No registered users and 59 guests
