It is currently Tue Jul 22, 2025 6:40 am
PostPosted: Thu Mar 02, 2017 7:21 pm
Hi all
I'm looking at getting a s/h tacho for the clubby and would like to be able to check that it works before buying. Can I bench test or does it have to be connected to car wiring?
Any help much appreciated.
P.S. Can't believe how much fun it is to drive an old mini. Just popping down to the shops is an adventure!
Eiles
PostPosted: Thu Mar 02, 2017 9:01 pm
no simple way to test it - it's possible, but you'd need to make / buy something that simulates the make-and-break distributor output
if you want to test before buying, take your mini with you and hook it up
PostPosted: Thu Mar 02, 2017 9:48 pm
Thanks for info Simon.
Eileen
PostPosted: Fri Mar 03, 2017 6:41 am
shnitzee wrote:
Hi all
Eiles
Its a little tricky...but you can inject a square wave into the unit...and vary the frequency etc
PostPosted: Fri Mar 03, 2017 6:56 am
If you have a spare square wave generator lying around :D :D :D
PostPosted: Fri Mar 03, 2017 5:23 pm
I was going to ask 'what's a square wave?'.
PostPosted: Fri Mar 03, 2017 7:41 pm
The Mini King
Square wave can be defined as a non sinusoidal periodic waveform that can be represented as an infinite summation of sinusoidal waves. It has an amplitude alternate at a regular frequency between fixed minimum and maximum value with the same duration. Square wave generator are generally used in electronics and in signal processing. The square wave is the special case of rectangular wave. The square wave generator is just like a Schmit trigger circuit in which the reference voltage for the comparator depends on the output voltage.
a Schmitt trigger is a Comparator circuit with hysteresis implemented by applying positive feedback to the non inverting input of a comparator or differential amplifier. It is an active circuit which converts an analog input signal to a digital output signal. :wink:
PostPosted: Fri Mar 03, 2017 8:53 pm
I just wondered how big a syringe I'd need to inject one....
Cheers, Ian
PostPosted: Fri Mar 03, 2017 10:24 pm
I think John is trying to say that it would be easier connecting the tacho to the car wiring......
PostPosted: Sat Mar 04, 2017 12:39 am
I gave up after the first sentence!
Cheers John :)
I'll test it in the car.
PostPosted: Sat Mar 04, 2017 9:28 am
Geeez John , you either have to go and take your meds , or go and get some new ones :shock: :D ,
bloody head hurts after reading that :P .
PostPosted: Sat Mar 04, 2017 11:16 am
Hey John,
You can make your own SWG using the ubiquitous (been looking for a reason to use that word!) uA741 OP Amp... :D
http://www.circuitstoday.com/square-wav ... ing-ua-741
PostPosted: Sat Mar 04, 2017 3:32 pm
I think John has just learnt about the copy and paste function in his computerator...
https://www.efxkits.us/square-wave-gene ... ng-op-amp/
PostPosted: Sat Mar 04, 2017 9:27 pm
hee hee, i was going to sayulater exactly the samelinular thing as John saidorator :-)
PostPosted: Sat Mar 04, 2017 9:59 pm
shnitzee wrote:
Hi all
Eiles
After ALL that, are you still "appreciating" the help you've been given? Just as well you like driving them!
