It is currently Tue Jul 22, 2025 10:52 pm
PostPosted: Fri Mar 03, 2017 5:12 pm
Can you buy a single piece flexolator as per original spec for 71 GT? (The back or the seat and base of the seat is one piece rather than 2).
Does anyone have original spec width? I am guessing they were 13"? I can find 12" and 14" flexolators but not 13".
Also can you buy the correct Length colour coded springs to fit these?
I know minispares etc sell things "that will do the job".. but I am looking to get it right!
PostPosted: Fri Mar 03, 2017 6:33 pm
Try Newton Commercial
http://www.newtoncomm.co.uk/cars/classi ... 3-mk4-mk5/
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Sat Mar 04, 2017 7:12 am
Thanks - but newtons don't have the original type that I want.
PostPosted: Sat Mar 04, 2017 9:28 am
This is a picture of what I am after:
PostPosted: Sat Mar 04, 2017 11:39 am
I'm also interested, but part side question, can you put rubber diaphragms in this style seat instead?
Sent from my SM-G900I using Tapatalk
PostPosted: Sat Mar 04, 2017 11:46 am
Yes you can fit rubber diaphragms... frames are same shape.. but the holes drilled in the frames for the springs or clips are in slightly different locations.. but new holes could be drilled/old ones welded..
but yeah I want to go original...
