It is currently Tue Jul 22, 2025 4:09 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Feb 28, 2017 12:33 pm
the question is
Why after fitting another cam and head has the temp gone up
1- has some hidden rubbish come out of the head and blocked up some of the radiator
2- is the jetting wrong for this cam/head setup
head gasket wasn't a 1 way fitting one as in marked front (had a 6 cyl Holden once that i put the head gasket on the wrong way and caused it to run hot)
Ignition has been checked and double checked. Max advance is 30 deg using the black box
The temp gauge didn't just change mysteriously while the engine was out
So its going to be a radiator out and pull apart to check for blockages and fit a filter sock to the inlet to catch further rubbish
Anyone know where to buy a suitable size filter sock for a realistic price
1970 MK2 Cooper S
PostPosted: Tue Feb 28, 2017 12:54 pm
"Little over half". Do we know what this actual temperature is, in degrees C...?
PostPosted: Tue Feb 28, 2017 2:32 pm
According to winabbey:
winabbey wrote:
Just had a look at the BMC engineering drawing for the temp gauge - part AYA9168.
It says "52 degrees C at the Cold position and 120 degrees C at the Hot position".
viewtopic.php?p=1012092#p1012092
PostPosted: Tue Feb 28, 2017 5:00 pm
That's why I suggested testing the gauge with a kettle and thermometer.
PostPosted: Tue Feb 28, 2017 5:20 pm
Doesnt the sender have to be earthed to work?
1970 MK2 Cooper S
PostPosted: Tue Feb 28, 2017 6:22 pm
Ahhhhhh yeah...well no, ya puts yer two leads to the sender and boil that sucker :shock:
PostPosted: Tue Feb 28, 2017 8:26 pm
Radiator filter sock, use women's little stocking socks. A few $ at woolies.
PostPosted: Tue Feb 28, 2017 11:20 pm
I use a coolfilter. Only catches what will block the radiator, and much more durable.
PostPosted: Wed Mar 01, 2017 6:25 am
Who has 2 leads to their sender
1970 MK2 Cooper S
PostPosted: Wed Mar 01, 2017 6:35 am
Yes to test it you will need to earth it. Alligator clip or wire twisted around thread and earthed to car.
PostPosted: Wed Mar 01, 2017 6:13 pm
BUT in the absence of a decent earth...just put your Black/Negative lead on the body of the sender...
Heeeee heee...
https://www.youtube.com/watch?v=eXNBlH0c4_U
PostPosted: Thu Mar 02, 2017 5:28 pm
Well today the radiator had open heart surgery
So what i found was about half the tubes were blocked with rusty mud
And even blocked at the bottom
I was nearly going to give in and just buy a new radiator
But I said stuff it and continued on
So with some elbow grease i cleaned them all out and re-soldered it back up
Took it to the radiator shop for a pressure test and to paint it black
Should have it back in the morning
The car will probably make ice cubes now :wink:
1970 MK2 Cooper S
PostPosted: Sat Mar 04, 2017 11:36 am
Well the radiator is back in and test run done
Temp Gauge sits perfectly on half whether i am driving around town of ripping down the highway
So mission accomplished
1970 MK2 Cooper S
PostPosted: Sat Mar 04, 2017 2:19 pm
Good stuff.;)
PostPosted: Sun Mar 05, 2017 12:06 am
By chance have you removed the drain plug at the back of the block on the drivers side to see if that is clear as well?
Users browsing this forum: 1071 S, Andosoft and 69 guests
