It is currently Wed Jul 16, 2025 4:01 pm
 Post subject: Right hand tank pattern
PostPosted: Wed Feb 19, 2014 5:40 pm
Has anyone got a pattern / measurements for the right hand tank fitment? I need to cut the hole to fit the tank and want to make sure I get it right :shock:
cheers,
CJ
PostPosted: Wed Feb 19, 2014 5:48 pm
Just trace it on to a piece of paper and reverse it for the right hand side.
I hope that makes sense , when you start doing it you will see how easy it is .
PostPosted: Wed Feb 19, 2014 6:40 pm
that sounds simple enough
PostPosted: Wed Feb 19, 2014 7:13 pm
LOL, Yeh , Simple enough but not correct.
The Right hand tank hole position on a cooper s is not the Mirror Image of the Left hand Side.
Here is what you need................
PostPosted: Wed Feb 19, 2014 7:39 pm
Why couldn't the BMC make it easy :roll:
PostPosted: Wed Feb 19, 2014 8:06 pm
BMC didn't do easy.
It's easy once you know how.
PostPosted: Wed Feb 19, 2014 8:09 pm
just checked this layout on my car and it is bang on correct :wink:
PostPosted: Wed Feb 19, 2014 8:23 pm
cheers sitnlo62 I will print that out and take it to the shed :mrgreen:
PostPosted: Wed Feb 19, 2014 8:51 pm
heh heh heh, you are in a class of your own!!!
PostPosted: Sun Dec 25, 2016 4:12 pm
Damn it really... the panel shop doing my car used a template from the left side to do the right side of mine how far out will t be?
Jenk.
PostPosted: Sun Dec 25, 2016 4:34 pm
Is the tank in? If so, then close enough. :-) :-)
PostPosted: Sun Dec 25, 2016 4:46 pm
no its not do you think it'll still fit in?
Jenk.
PostPosted: Sun Dec 25, 2016 5:33 pm
I did mine mirror image, tank fits but less neck sticks out.
PostPosted: Sun Dec 25, 2016 6:35 pm
That's OK I can live with that... thanks doc.
Jenk.
PostPosted: Sun Dec 25, 2016 7:47 pm
The right hand side tank aperture is 6mm closer to the centre of the car and at the same height as the left hand aperture. Most people putting in a right hand tank just use a mirror image of the LHS so any issues would've shown up by now.
