It is currently Wed Jul 16, 2025 5:42 am
PostPosted: Mon Nov 21, 2016 11:30 am
no, temperature won't cause that - maybe running lean or the coil is starting to die
PostPosted: Mon Nov 21, 2016 1:46 pm
You could try pulling the choke out a little...if improves it is running lean for some reason.
PostPosted: Mon Nov 21, 2016 2:54 pm
Had something that sounds similar that ended up being the carb. Switched it out for a different one and smooth as
Mini-less ... for now
PostPosted: Mon Nov 21, 2016 4:35 pm
GuamMini,
At least your coolant system is in good shape!
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Mon Nov 21, 2016 6:05 pm
GuamMini wrote:
You guys could be right it has to be something with the fuel. I don't know if water could get into the tank, but I will check when I filled it up with more fuel it seems like it got worst. It has a brand new ignition coil.
Water could definitely get into the Fuel Depots tanks though...either dump it and start again or try dosing the tank with say a pint of Methylated Spirits :idea:
PostPosted: Mon Nov 21, 2016 8:57 pm
what fuel are you running?
PostPosted: Mon Nov 21, 2016 11:27 pm
what fuel did you put in? I am in Thailand at the moment and "gasahol" is frequently labeled as 95 Ron but is a blend of ethanol and petrol. if you've put a fuel blended with ethanol in it then you will need to adjust the mixture as ethanol has less energy density than petrol.
I'd say drain the tank, should be a tap that you can reach underneath the tank.
PostPosted: Mon Nov 21, 2016 11:29 pm
Run 95 bp in it. Ultimate causes to many issues
PostPosted: Tue Nov 22, 2016 5:09 pm
Do you seriously believe BP (as in British Petroleum) fuel would be available in Guam?.......
67 Deluxe
Dry suspension
PostPosted: Tue Nov 22, 2016 8:22 pm
Mobil and Shell are there...why not?
http://www.guampdn.com/story/news/local ... /77684334/
PostPosted: Wed Nov 23, 2016 5:26 pm
BP are in the US (Or were until they had an issue in the Gulf of Mexico !) They bought Amoco and run refineries and other assets in Texas and elsewhere
'78 1275 LS (Under Repair, Dependant #1's car)
'72 GT Powered Clubman (Mine)... Under (re) construction
PostPosted: Mon Jun 26, 2017 2:57 pm
Go for an electronic dissy with adaptive dwell. The coil runs cooler. No condenser issues. No points bounce.
PostPosted: Mon Jun 26, 2017 6:46 pm
There are not to many to pick from if you go for a drop in unit and keep your dissy. Accuspark or powerspark come to mind if your on a budget. Or go for whole new electronic dissy. Plenty on ebay for $140. Does your current dissy have vacuum advance and a top entry cap? You probably have a 29D if original. I think a 45D is the replacement for a vacuum dissy. 43D for non vacuum.
