It is currently Sat Jul 26, 2025 10:47 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Oct 25, 2016 6:38 am
Right so since last post I have replaced clutch hose & pipe and put in a new slave push rod. The new push rod was actually ~10mm shorter than the one that was in there.
With the new push rod installed (no return spring) I cannot get it into gear with the engine running, with the longer (old) push rod I can get into gear (still no return spring).
As soon as the return spring goes back on, I cannot get it into gear, with either push rod.
At this stage I think I will replace the slave cylinder (everything else around it is new, may as well!) although it does look to be working correctly with no leaks etc.
PostPosted: Tue Oct 25, 2016 7:10 am
Does the slave cylinder have a seal spreader in it? Most new ones don't, but need it.
See my other thread re this. I make new ones...!
PostPosted: Tue Nov 08, 2016 4:33 pm
Thought I'd post a quick update to happily close out this thread.
I replaced the slave cylinder this evening with a new genuine one and this has resolved the issue - with the spring back on i can change gears with the engine running. Took her for a drive around the block and the clutch pedal felt great!
Thanks to all who contributed advice!
PostPosted: Tue Nov 08, 2016 9:23 pm
Awesome - happy Mini = :-)
