It is currently Sun Jul 27, 2025 8:08 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Tue Nov 01, 2016 5:01 pm
winabbey wrote:
DavidE wrote:
I thought the seat mounting captive nuts were in the front face of the cross member?
... which you can see in the diagram posted above. :wink:
Exactly.
PostPosted: Tue Nov 01, 2016 5:07 pm
DavidE wrote:
Exactly.
And a 78 1275LS has captive nuts on the top ! Standard !
'78 1275 LS (Under Repair, Dependant #1's car)
'72 GT Powered Clubman (Mine)... Under (re) construction
PostPosted: Tue Nov 01, 2016 5:12 pm
From http://classicregister.com/id-pages/how-identify-1978-leyland-mini-1275-ls
"The front seats in a 1275 LS also feature an adjustable base, to slide the seat back and forward. This feature was unique to the 1275 LS, being more advanced than the seats installed in the 998 LS. A slightly different lever on the side of the seat used in the 1275 LS to fold the seat forward, for rear passenger entry."
PostPosted: Tue Nov 01, 2016 5:31 pm
Yes, no dispute with that.
Below is a part of the engineering drawing for the late Clubman crossmember (HYE0484) that shows the eight projection weld nuts (MYH0221) on the top of the crossmember, as well as those on the front. It's very poor quality so I've cropped it to show the side, end and top views of the part.
Also below the drawing for the nuts themselves. Hope it's of interest.
By the way, the crossmember is made from .039" steel CR CQ, whatever that is.
P.S. Click on an image to get a larger view.
PostPosted: Tue Nov 01, 2016 5:35 pm
Thanks Winabbey. Those nuts are the ones. 0.039" is 1.5mm, which seems a bit heavier than what we have.
Anyway. We'll have to come up with a plan. (And one to last another 38 years :shock: )
PostPosted: Tue Nov 01, 2016 5:41 pm
Drawn by R. Matthews ! That's my last name ! :shock: No relation I would think.
PostPosted: Tue Nov 01, 2016 6:06 pm
Huh. I must have 1275 seats in my 78 shell..
Sent from my SM-G900I using Tapatalk
PostPosted: Tue Nov 01, 2016 6:55 pm
78Clubbie wrote:
0.039" is 1.5mm,
Oops, shouldnt have done the calc in my head ! 1mm :oops: :oops: :roll:
PostPosted: Tue Nov 01, 2016 9:11 pm
Mine has the same issue. As the seat and bracket moves slightly when you sit in it there is constant cyclic stress on the thin sheet the nut is welded to. After a while they crack.
I would suggest a plate on the inside of the cross member to distribute the load as it will reoccur if you just repair it back to original.
Alec
PostPosted: Tue Nov 01, 2016 9:24 pm
Hi Winnabey
How many of the clubbie engineering drawings do you have access to?
Alec
PostPosted: Wed Nov 02, 2016 8:17 am
Cold Rolled C.... Quality Maybe?? (a guggle search turns up commercial quality)
Nick
PostPosted: Wed Nov 02, 2016 9:49 am
1275LS wrote:
Hi Winnabey
Quite a few, but of varying quality. If I see a topic where a drawing I have might help I post it.
PostPosted: Thu Nov 03, 2016 9:14 pm
Cold Rolled Commercial Quality
Nothing special at all.
PostPosted: Thu Nov 03, 2016 9:30 pm
They were always too damned thin to last. Should have been 1.6mm.
There again nobody expected Minis to last over 50 years! ;)
