It is currently Sun Jul 27, 2025 8:16 am
 Post subject: Valve Guides Whats Best
PostPosted: Mon Oct 31, 2016 5:33 pm
Whats the best Valve Guide to use
Cast Iron or Bronze
1970 MK2 Cooper S
PostPosted: Mon Oct 31, 2016 5:35 pm
cast iron guides for normal valves
bronze guides for stainless valves
"Generally"
PostPosted: Mon Oct 31, 2016 7:02 pm
Online
The original cast iron guides but with k-liners fitted. Not cheap, but they give best heat transfer and run minimum clearance.
Work fine with stock valves or SS ones.
[edit]
re bronze guides, I do run a set in my car. These current manganese bronze ones tend to shrink when fitted, definitely need a 9/32" reamer through them after fitting. And one of mine even then tried to grab an exhaust valve when first run, so I had to pull the head and ream them a second time. To be sure, to be sure...
That was 50,000 miles ago (with 1.5:1 forged rockers) and they are still working fine.
Users browsing this forum: drmini in aust and 97 guests
