It is currently Sat Jul 26, 2025 10:28 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Wed Oct 26, 2016 7:40 pm
Help pretty please. I'm in the wars again.
Mini is ready for roadworthy and rego. Went for a burn around my paddock and up and down the court, can't get second gear, everything else is there. Gearbox has been overhauled by a professional. Removed the carbies and extractors, watched the linkages while someone went through the gears, the left remote lever at the back of the box moves up and down ok, can see the gear select lever move through all gears except second, which only moves up a touch, no amount of pulling upwards will get it to second. When pulled, you can feel it sorta wants to go and the gear is half engaged. I don't really want to pull the unit out again. Does anyone have any ideas before I do this.
Thanks.
Last edited by Minicooper4me on Fri Oct 28, 2016 5:46 pm, edited 2 times in total.
PostPosted: Wed Oct 26, 2016 8:16 pm
Are the linkages n right splines? Only needs to be one out to not work, does it select 4th/ reverse easily?
PostPosted: Wed Oct 26, 2016 8:20 pm
Yep, all gears including reverse are ok.
PostPosted: Wed Oct 26, 2016 8:57 pm
PM Sent
PostPosted: Thu Oct 27, 2016 2:21 pm
it could be something as simple as a nut or stone stuck inside the remote housing - I'd take the linkage off the shaft that goes through the diff housing and try moving the gearbox side of the linkage by hand. A long socket on an extension works well for changing gears that way
PostPosted: Thu Oct 27, 2016 5:49 pm
Is it a rod change ? Make sure the plate under the selector is around/installed the right way
'78 1275 LS (Under Repair, Dependant #1's car)
'72 GT Powered Clubman (Mine)... Under (re) construction
PostPosted: Thu Oct 27, 2016 6:47 pm
nup
mc4me wrote:
watched the linkages while someone went through the gears, the left lever at the back of the box goes to first ok, when moved to second it only goes up a touch
PostPosted: Fri Oct 28, 2016 5:50 pm
Thanks for the advise Simon.
Have removed the remote extension housing, nothing out of place, have removed the linkages and changed gears manually with socket/extension as suggested, get all gears but second. I'm convinced it's in the box. Bugger.
PostPosted: Fri Oct 28, 2016 5:53 pm
What plate is this 78Clubbie ?. Yes it is a rod change.
PostPosted: Fri Oct 28, 2016 6:00 pm
The little cover under the gear stick..... I presume.
PostPosted: Fri Oct 28, 2016 6:05 pm
I'm confused...
PostPosted: Fri Oct 28, 2016 7:27 pm
As Peterb said. It's the cover on the underside of the the gear shift.
However, since you have disconnected the rod change and still have a problem it wont be this.
PostPosted: Sat Oct 29, 2016 7:43 am
Looks like it could need surgery. Somethings not right inside. :-(
There's a few things that could cause it ....inside. Have you tried selecting gears directly using shaft sticking out box?
PostPosted: Sat Oct 29, 2016 11:14 am
Is it a 3 synchro or 4 synchro box? If 3 synchro, if 1st gear has been assembled out of phase on the 1st & 2nd hub the interlock plunger will prevent second gear engaging. I know this from bitter experience!
PostPosted: Sat Oct 29, 2016 11:35 am
all rod changes are 4 syncro
Users browsing this forum: Bing [Bot] and 102 guests
