It is currently Mon Jun 23, 2025 11:07 am
PostPosted: Thu Oct 27, 2016 2:18 pm
Hi all, having a head gasket issue on 998 .080" oversized bore. Blowing the gasket between 3&4. Anyone recommend what head gasket to use. Thanks.
PostPosted: Thu Oct 27, 2016 4:40 pm
Make sure that both the head and block surfaces are dead flat. Type of gasket unsure though, ACL used to be the go but they are no longer made
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Thu Oct 27, 2016 7:13 pm
http://www.youtube.com/watch?v=XEaRMR-RZPo
Janspeed thought fuse wire could sort the issue, never really heard of this working first hand.
PostPosted: Thu Oct 27, 2016 9:36 pm
I used a 1275 gasket on a 68mm bore 998 with a 12G202 head, but a few water holes had to be moved in head and block.
PostPosted: Fri Oct 28, 2016 8:32 am
Thanks for the advice. Might explore the 1275 option further. I've heard that they will fit with some modification to align water jacket
