It is currently Sun Jul 27, 2025 8:03 am
PostPosted: Thu Oct 27, 2016 6:12 am
Hello I was wondering if anyone can tell if there is problems with bolting a MPI head onto a series (pre a+) 1275? Thanks Scott
PostPosted: Thu Oct 27, 2016 8:00 am
Shouldnt be any they were the same as everything else.
Its the mpi blocks that are different cause they dont have a distributor.
PostPosted: Thu Oct 27, 2016 8:10 am
. Thanks, the CC is the same size, it all looks straight forward, I am assuming manifolds will bold straight up
PostPosted: Thu Oct 27, 2016 5:54 pm
:lol: Crikey, if you put a MPI head on it, you'll have to get it re-engineered as a new car.
PostPosted: Thu Oct 27, 2016 6:21 pm
I have an MPI head on a 1275. It did not have fittings for the standard temp sender, bypass hose and heater outlet.
It may not be a problem for your application, and some MPI heads may have these fittings.
PostPosted: Thu Oct 27, 2016 8:59 pm
Ta, doesn't sound too scared
PostPosted: Thu Oct 27, 2016 9:01 pm
. I know, it will create expectations of fancy injection stuff
Users browsing this forum: Bing [Bot] and 99 guests
