It is currently Sun Jul 27, 2025 7:32 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Fri Oct 21, 2016 4:06 pm
winabbey wrote:
I'm guessing the change of part numbers for the leads is as a result of the 29D4 distributor introduction, although the cable lengths are the same.
Thankyou Doug
PostPosted: Sat Oct 22, 2016 6:59 am
Hello All,
For what it's worth, I found the BMC listed lengths for plug leads to suit the 23D4 distributor too short on leads one, two & three, & way too long for the coil lead (mine is mounted on the generator).
The lengths on my car from centre of 90 degree plug cap to the cut end of the lead are as follows.
# 1, 325 mm. # 2, 315 mm, # 3 225 mm, # 4, 245 mm, & the coil lead overall is 205 mm.
Naturally, these lengths are for the side entry cap.
PostPosted: Sat Oct 22, 2016 9:06 pm
Mick wrote:
Decent close up of a Mk2 lead here:
Where can I find some of those numbered caps?
Users browsing this forum: acarseldine and 100 guests
