It is currently Sun Jul 27, 2025 5:00 pm
PostPosted: Sun Oct 16, 2016 11:20 am
So,
Long story short we are working on resurrecting #1 dependants 1275LS and have been trying to diagnose a significant miss under load.
Checked the usual suspects (Fuel, air, electrical etc) and sorted some issues but still no go.
Took the head off today and can see (Apart from lots of soot :oops:) that there may be tracking between #2 and #3. See pic
Would appreciate thoughts from those more knowledgable than me if this is significant or minor.
There is signs of unburnt fuel/oil in #3 which may or may not back up my diagnosis.
Top of gasket #2-#3
Underside of gasket
Head
Block face
Sorry for all the pics. Seemed the easiest way to describe
'78 1275 LS (Under Repair, Dependant #1's car)
'72 GT Powered Clubman (Mine)... Under (re) construction
PostPosted: Sun Oct 16, 2016 12:06 pm
Hi,
I've just gone through that same issue with that gasket giving way between No's 2 & 3 on my 1275. The engine had only driven 3500km since rebuild. After checking that there was no damage to the head or block, I replaced the old fibre gasket with a high performance copper/aluminium one. So far it's purring beautifully, having only driven an additional 800km in five months and I've re-tourqued the head twice just no make sure.
Sean
PostPosted: Sun Oct 16, 2016 12:07 pm
The gasket doesn't show any clear indication of blowing out, but there's a good chance while the head is off to look at other things, so no loss there. The gasket is thin at that point, so its normal that it will look a little different to the rest of the gasket, but if it was tracking there would be metal missing, especially under load as there is so much heat and compressed mixture flying about.
Your miss might be electrical, or fuel related still.
PostPosted: Sun Oct 16, 2016 4:11 pm
Was there a compression test done before it was pulled apart? If it was blowing between 2 & 3, the compression on both these will be down.
PostPosted: Sun Oct 16, 2016 4:43 pm
Compression was even across all 4 - ~ 150.
Wasn't expecting gasket issue. Was pulling down to view/check.
Thought there may have been something funky going on once it warmed up.
PostPosted: Sun Oct 16, 2016 7:11 pm
That is pretty normal having a bit more heat in that area. there are two side by side exhaust valves there. Speaking of exhaust valves, they do look a bit low down in the seats. I think you should consider inserts .
"Let us remove your "SHORTS"
PostPosted: Sun Oct 16, 2016 8:43 pm
If the valve guides are very worn then oil can leak through them quite a fair bit. While the head is off, take the springs off and check the valves one by one and see if there is any play on the valve guides. Good time to put new valve stem seals too. If you buy a head gasket kit it should come with all this.
PostPosted: Mon Oct 17, 2016 11:53 am
take the studs out of the block and clean the face with an oilstone, get the head rebuilt & surfaced
PostPosted: Mon Oct 17, 2016 12:38 pm
Then countersink the head stud holes in the block to avoid raising burrs against the gasket.
PostPosted: Mon Oct 17, 2016 6:05 pm
Thanks guys.
That was the other reason for taking the head off. Gives an excuse to "refurb" the seals and/or the seats. (And maybe go a bit further for a bit of performance :twisted: ) Just have to convince dependant #1 to fork over some cash. (Not sure where his scottish nature came from, oh wait my wifes maiden name was Ferguson ! :roll: )
I haven't pulled the valves out yet, or checked head for straightness. Will do that before sending off for refurb.
PostPosted: Mon Oct 17, 2016 6:07 pm
Stud removal and insertion method ? Just use 2 nuts ?
PostPosted: Mon Oct 17, 2016 6:08 pm
Thinking I should revisit Electrical. :idea:
PostPosted: Mon Oct 17, 2016 6:20 pm
Yes, especially as it happens under load. A blown gasket screws you over completely.
I like to do a clean sweep with rotor, cap, leads and plugs. Consider the coil too if its old. Maybe a module as well if you're still running points. Set and forget from one end of the year to the next.
PostPosted: Mon Oct 17, 2016 6:30 pm
Thanks Mick
We thought we had it running OK and then changed to a module in the dissie. Been chasing our tails ever since. Have swapped stuff around with known good stuff, but I fear we got lost along the way. So once we sort the head and take the opportunity to reco/upgrade, we will start from the beginning.
PostPosted: Mon Oct 17, 2016 7:58 pm
I have stud removers - looks like a spark plug socket but grips the stud below the thread. 2 nuts will work but you've gotta be really careful not to crush the threads
Users browsing this forum: timmy201 and 89 guests
