It is currently Sat Jul 26, 2025 10:39 pm
 Post subject: Diff Help
PostPosted: Wed Oct 12, 2016 8:04 pm
so I have installed the motor in the sub frame of my project, fitted universals, only to find there is too much play in the diff output shaft. so pulled it all down and removed the diff.
can people shed light on most likely worn parts to replace.
- there is lateral movement in both shafts,
- the crown wheel side moves in and out approx. 0.63mm from what the feeler gauges says
- seems to be some movement in the main pit that holds the spider gears.
ideas on how to repair, would a kit from mini spares fix it?
do I need new bearings?
how do you get the bearings off?
 Post subject: Re: Diff Help
PostPosted: Wed Oct 12, 2016 8:24 pm
need a 3 legged puller to get the bearings off
you'll need a new diff pin, and washers for the spider gears and thrusts
have a look for a diff rebuild kit
PostPosted: Wed Oct 12, 2016 9:16 pm
Thanks for that. Best place to get a kit??
PostPosted: Thu Oct 13, 2016 7:55 am
if you support your local mini specialist for the parts you need
then i`m sure they will support you in return
The Uk parts companys are a fair way away to ask advise
about Aussie cars , esspecially when their UK cars are totally different to ours
PostPosted: Thu Oct 13, 2016 9:13 am
A list of Australian Mini businesses is here. Some have online shop websites. viewtopic.php?f=41&t=83593
Here's an example of one type of rebuild kit, or just buy the components you need.
http://minikingdomonline.com.au/product ... wheel-kit/
PostPosted: Thu Oct 13, 2016 6:23 pm
Fully agree, keep it local, keep our suppliers in business, keep people employed. It would be a sad day if the locals shut up shop.
PostPosted: Thu Oct 13, 2016 7:33 pm
I agree, Some people don't understand how much work we do sourcing the right quality parts and keeping stock. Makes it very hard for us when people direct others to buy from overseas when parts can be bought here. Support suppliers that support the local Mini community. We are always here with friendly advice like Matt said.
"Let us remove your "SHORTS"
PostPosted: Thu Oct 13, 2016 7:46 pm
Once online purchases like that attract tax, (and eventually they will) those price differences will disappear.
Sent from my SM-G900I using Tapatalk
PostPosted: Thu Oct 13, 2016 8:00 pm
Thanks all appreciate the comments. Will start ringing round tomorrow.
Users browsing this forum: Bill B, Bing [Bot] and 99 guests
