It is currently Sun Jul 27, 2025 4:52 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Mini air con
PostPosted: Sun Oct 09, 2016 10:10 pm
How do I do that?
PostPosted: Sun Oct 09, 2016 10:20 pm
Got a multimeter?
Yep, 14ish volts into one side of the fuse
PostPosted: Sun Oct 09, 2016 10:27 pm
Now just see if the other side is earthed to the body.
PostPosted: Sun Oct 09, 2016 10:31 pm
Yep, got the ohms setting on and there is no resistance. From my limited knowledge that means an earth issue?
PostPosted: Sun Oct 09, 2016 11:09 pm
Thats good and bad- bad cause its there but good cause its easy to find.
Disconnect the relay module, ac switchpack, thermostat and the other items in the circuit and retest.
If it still earths then its probably a wire thats rubbed through somewhere, if good then reconnect things till you get an earth connection again.
Chances are either: the thermostat has given up as its earth mounted, bit could be fried relay unit or crook switchpack.
PostPosted: Sun Oct 09, 2016 11:12 pm
Everything is still disconnected and it's earthing. Sounds like a rubbed wire. I'm not looking forward to going through the whole loom to find it. Maybe I should just rewire the thermo/relay/switch pack to the fuse box myself.
PostPosted: Sun Oct 09, 2016 11:14 pm
Thank you soo much for your help too! It's nice to have a helping hand, so to speak, when doing this stuff for the first time
PostPosted: Mon Oct 10, 2016 5:16 am
Nice fault finding, great to see this level of help on a Sunday night.
What were the signs the compressor had no power?
I'm wondering if mine needs a regas or has a similar problem to yours - blows air fine but not cooled. However something is kicking in when I turn on the AC, I hear it in the bay and the revs drop.
Was yours like that or no signs of compressor life?
Mini-less ... for now
PostPosted: Mon Oct 10, 2016 9:32 am
The blower still worked and I got the drop in revs when it turned on, but it just blew lukewarm air. I presumed it needed a regas, but after the aircon guy had left it still blew lukewarm air so I just chucked a multimeter on the plug...no power. A6 fuse is the one that is supposed to kick on for the compressor
PostPosted: Mon Oct 10, 2016 9:38 am
Thanks for the feedback - is the A6 fuse easy to find?
any luck sorting yours out?
PostPosted: Mon Oct 10, 2016 11:14 am
I Pm'd you with the location.
I currently have the dash off and about to start rewiring from the A6 fuse to the thermostat/switchpack/relay module. Wish me luck!
PostPosted: Mon Oct 10, 2016 11:15 am
A6 is for the whole AC system, not just the compressor.
PostPosted: Mon Oct 10, 2016 12:14 pm
Here's the fusebox
PostPosted: Mon Oct 10, 2016 12:46 pm
In my experience a rubbed through wire will usually give an intermittent fault or short, rather than something that seems fairly 'connected' like you are describing. What other work or changes have been done lately? I'm thinking along the lines of a recent screw through wiring behind a panel maybe?
Often the location of a loom fault can be found by checking for continuity while moving parts of the loom carefully. I've done this before by using a meter that has an an audible buzzer or similar so I don't have to watch anything.
I'm not familiar with the Rover wiring at all, but would be checking where the OEM connection points are first just to see what I could see. Where is the junction point SJ29 located physically? Is it at one of the 3 plugs?
Don't listen to what I am saying... just understand what I mean.
