It is currently Tue Jul 29, 2025 4:16 pm
 Post subject: Speedo correction
PostPosted: Tue Sep 27, 2016 9:37 pm
Require some expert help please.
Just about to reinstall my motor/gearbox in a 66 Deluxe. Motor is a 1098, 3.44 diff, 165/70 x 10 tyres, standard black 90 mph speedo.
I'm sure the speedo will be out, maybe actually read under. Can the speedo gear/pinion whatsi thing be changed at the gearbox or do I really need to change the speedo out for cooper s. Not really keen on putting dymo tape stickers on the speedo.
Thanks.
 Post subject: Re: Speedo correction
PostPosted: Tue Sep 27, 2016 9:39 pm
it's for UK minis, but you'll find the right combination in here - http://www.guess-works.com/Tech/ratio.htm
PostPosted: Tue Sep 27, 2016 9:41 pm
And thanks again Simon. 2 out of 2.
PostPosted: Tue Sep 27, 2016 9:45 pm
lol, no worries
PostPosted: Tue Sep 27, 2016 9:55 pm
Just checked Simon, up to 6000 rpm, pretty well spot on. Happy with that.
PostPosted: Tue Sep 27, 2016 10:06 pm
awesome site
1968 Morris Mini Cooper S
PostPosted: Thu Sep 29, 2016 9:53 pm
Guess works sells the pinions as well just PayPal them and wait a couple of weeks
Did i tell you that all my minis are 850's ?
PostPosted: Sat Oct 01, 2016 8:53 pm
Bugger. I just checked this again, was reading the chart wrong. My speedo is the standard black 90mph 1408 turns per minute type as indicated on the speedo face. Speedo pinion and drive gears in the gearbox are 6 and 17 tooth types. The chart shows at 60mph indication on the speedo, actual speed is 66 mph. Without going to a Cooper S 120mph 1280tpm type speedo (unless I got it cheap), can the gears in the gearbox be changed to bring the tpm back to near 1280 tpm. Or, does anyone do reduction gears that screw on to the back of the speedo.
Any info much appreciated.
PostPosted: Sat Oct 01, 2016 9:12 pm
The guessworks calculator should suggest the best speedo drive gears given your diff ratio and speedo TPM. We have a similar issue (3.44 diff and Mini K 90mph speedo) and ordered the drive gears from guessworks.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Sat Oct 01, 2016 9:20 pm
Thanks Matt. I'll go back into guessworks and see whats available.
PostPosted: Sun Oct 02, 2016 7:43 am
Bugger. I just checked this again, was reading the chart wrong. My speedo is the standard black 90mph 1408 turns per mile type as indicated on the speedo face.
PostPosted: Sun Oct 02, 2016 7:51 pm
It's easy to read the chart wrong.
That's a bugger, same speedo as mine. I guess we'll be in the next bidding war for a 1280 cooper s speedo ! Happy bidding.
PostPosted: Sun Oct 02, 2016 8:08 pm
You may want to check the possibility and cost to recalibrate your existing speedo.
http://www.howardinstruments.com.au/
PostPosted: Sun Oct 02, 2016 8:15 pm
Thanks Doug, they may be the next best bet.
PostPosted: Sun Oct 02, 2016 8:48 pm
7/18 are the gears for a 1408TPM speedo and 3.44 diff if you can find them.
*witty signature*
