It is currently Sun Jul 27, 2025 11:12 pm
PostPosted: Sat Sep 24, 2016 1:13 pm
coke can, anything under that is illegal!!
1993 R32 Nissan Skyline GTR
PostPosted: Sat Sep 24, 2016 2:51 pm
The vehicle standards booklet I looked at from qld transport states that vehicles can be raised or lowered without approval as long as 2/3 of the original suspension travel in each direction is maintained. Then in a note at the bottom of the page " *Generally, a vehicle which maintains a minimum clearance of 100mm between the ground and any point on the underside of the vehicle (except a point on a tyre, wheel, wheel hub, brake backing plate or flexible mudguard or mudflap) will meet ADR 43."
Seems to be a bit of a grey area to me, depending on the vehicles suspension geometry you could potentially lower the car to be above the 100 mm and still be illegal.
Does anyone know the standard factory height of a mini and how much travel it has?
PostPosted: Sat Sep 24, 2016 3:51 pm
Coke can? Will a beer can do, I have those.... I like it! I'll give it a go out of interest...
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sat Sep 24, 2016 4:55 pm
Kennomini wrote:
Is that ADR apply to all minis or just 71 onwards?
100 mm for all cars. That's good clearance for the crap roads we drive on. Better than damaging our cars however for looks, lower is better.
Website: http://www.dutchysmini.com/
Facebook page: https://www.facebook.com/Dutchysmini/
Previously owned the Red VTEC Mini (B16A)
Project currently on the go:
1961 Morris mini
Engine conversion - WRX EJ255
PostPosted: Sat Sep 24, 2016 6:10 pm
Don't know why you're all having problems....? :shock:
PostPosted: Sat Sep 24, 2016 8:25 pm
Na, still no good. That rear diff height is a bit sus !
PostPosted: Sat Sep 24, 2016 9:24 pm
Milatsmadmini
Rah roh... My Moke doesn't qualify with that... Even with the coke can on its side!
PostPosted: Sun Sep 25, 2016 2:20 pm
I wonder how they expect a minimatic on the standard hydro suspension to pass that.. Its never ever been over 100mm in its entire life! I've learnt where the speed bumps are in my local shopping centre that I can't even attempt to go over haha
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
PostPosted: Sun Sep 25, 2016 7:25 pm
I know of one fella who got so frustrated (with the lack of factual common sense etc) that he locked his car whist it was over the pits and told the Rocket Scientist "inspector" to call the Police :roll:
PostPosted: Sun Sep 25, 2016 10:41 pm
and what was the result?
1961 Morris mini
PostPosted: Mon Sep 26, 2016 7:59 am
The "inspectors" supervisor was called in and told the "inspector" he was wrong and to let the customer go on his way...
PostPosted: Mon Sep 26, 2016 8:03 am
Good result. It would be nice if more people had common sense these days.
1961 Morris mini
Users browsing this forum: Barkfast and 105 guests
