It is currently Sun Jul 27, 2025 11:22 pm
PostPosted: Tue Sep 20, 2016 10:28 pm
Do they have one between the plate and arm ....can't for the life of me remember .
Just reassembling now so can make one if needed ...
Also the handbrake quadrant has nylon washers top and bottom right ?
Any one with a pic of the types of washer and clips to use ?
Many thanks !
Simonw
Brisbane QLD
1st car - 1964 Mini Panelvan 850
Previous - 1978 Leyland LS 1275 Gold
- 1969 Mini K
PostPosted: Wed Sep 21, 2016 7:26 am
Have you tried the likes of Mini spares UK on their parts catalogues. The exploded diagrams are great for showing the assembly order and what's actually fitted where. :-)
PostPosted: Wed Sep 21, 2016 7:46 am
Not shown in Mini King catalog. I pulled a backplate off a GT this week and there was none there.
There is a paper gasket behind the rear brake cylinder, but most people leave it out.
PostPosted: Thu Sep 22, 2016 12:54 pm
1. I've never seen a gasket between backing plate and swing arm.
2. The handbrake quadrant has only 1 nylon washer (21A1512) fitted to the top side - none underneath. The flat, coil spring washer (2K2545); followed by the spire clip (21A1513).
3. The parts diagrams show the coil spring fitted FIRST and the nylon washer next. Is this right? The nylon washer looks like it should go on first - partly as a dust seal.
PostPosted: Thu Sep 22, 2016 9:59 pm
Thanks guys!
@bill yes I was equally confused at the diagram too...
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Fri Sep 23, 2016 4:25 pm
Simonw
Brisbane QLD
- 1969 Mini K
