It is currently Tue Jul 08, 2025 8:54 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 542, 543, 544, 545, 546, 547, 548 ... 568  Next
PostPosted: Sun Sep 11, 2016 12:36 pm
Checked the tyre pressures & fluid levels & went for a run!
PostPosted: Sun Sep 11, 2016 2:35 pm
Yesterday saw the front drivers cone, trumpet, knuckle come out in one piece after removing the upper arm.
Today after visiting the BMC muster, attempt 1 at separating the trumpet from the cone. Tomorrow after the wd40 has done its thing - attempt 2 .... with a bigger hammer.
After 1 weekend, the swear jar is full!!!! (And i now know i need smaller hands for those upper arm hinge pins - especially with the engine still in place!!).
Sent from my SM-G900I using Tapatalk
"Evil will always triumph over good - because good is dumb"
1961 Mini 850 - sold 1997
1965 Mini Deluxe - sold 2013
1977 Mini LS - in build....
PostPosted: Sun Sep 11, 2016 4:53 pm
Replaced one side of the rear flare backings - took the wide one off and put an original S size on.....had to take out original flare clips to make flares sit properly. Now need to patch the holes....
Put the new standard flares on with the old mould to test.....not bad. Will do other side and fit new moulds tomorrow......only 3 1/2 weeks to Bathurst.... :shock:
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun Sep 11, 2016 8:19 pm
Reamed two radius arm bushes in the Lathe for a buddy of mine with my 13/16 machining reamer. worked a treat, very happy with the result.
PostPosted: Sun Sep 11, 2016 8:39 pm
Got to see it for the first time in 4 months. Its been in storage while we build cant wait to have it back in my shed.
PostPosted: Sun Sep 11, 2016 8:42 pm
Online
Topped up the tank, pumped up the tyres and drove it.
I love the stares and smiles from all the "mature" age folk as they reminisce the old days when they had a mini.
PostPosted: Sun Sep 11, 2016 9:47 pm
Welded some floor patches into my son's $355 `71 Clubby. Oh my aching knees! I'm getting too old for this, can't hardly see to weld either. :(
PostPosted: Fri Sep 16, 2016 1:09 pm
Floor is where he should be learning to weld! Fools job though =/
PostPosted: Sat Sep 17, 2016 4:04 pm
Bled and adjusted all 4 brakes, it actually stops without having to pump the pedal first!
PostPosted: Sun Sep 18, 2016 4:01 pm
Finally reunited with my S for a few weeks. Rekitted the clutch master and replaced the slave with an after market unit.
When swapping the clutch slave seal spreader for my old one I noticed the new slave cylinder does not have a circlip or groove to stop the piston coming out.
That was a trick used in the old days to counteract wear in the linkages.
Not sure if that is the reason they have done it or maybe they are just saving money in machining and a circlip.
PostPosted: Sun Sep 18, 2016 5:56 pm
https://www.bunnings.com.au/our-range/t ... /knee-pads
http://www.jaycar.com.au/led-headband-m ... r/p/QM3511
:D
PostPosted: Sun Sep 18, 2016 6:32 pm
Touched the rear window then walked inside
1968 Morris Mini Cooper S
PostPosted: Sun Sep 18, 2016 7:53 pm
went through the interior and screwed every thing up and tightened a heap of bolts... Amazing in the rush to finish assembly for the wedding how much I id by hand and didn't get enough tightness... Now all my rattles are gone.... even some screws were missing :-0
PostPosted: Sun Sep 18, 2016 9:13 pm
Nothing, got the flu, but had enough energy to go and get the remaining lot of Gulf Western 20W50 for $7.99 each, even though they said sold out at that shop.....they were on the bottom shelf at the back, so SCORED!
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun Sep 18, 2016 9:59 pm
Same here. Went to 3 shops before finding some still in store, and hidden on the bottom shelf.
Users browsing this forum: Bing [Bot], Phil 850 and 75 guests
