It is currently Mon Jul 28, 2025 12:24 am
PostPosted: Mon Sep 21, 2015 11:16 am
lockwood wrote:
When did the 12AUW round motors come in? my friends Cooper S is June 1967.
Over a year later, from Cooper S Car Number 4028.
PostPosted: Mon Sep 21, 2015 5:24 pm
miniron wrote:
:wink:
Minis have 2 different length wiper blades.
Early ones with original UK type Lucas motors and wiper panel have 10" blades.
Later ones with the OZ type round 12AUW Lucas wiper motor and OZ wiper panel have 11" blades.
The single speed OZ Lucas wiper motors originally had a 110 Deg wiping angle. This caused the RH wiper arm to hit the RHS windscreen rubber.
Later 2 speed OZ Lucas wiper motors had the wipe angle reduced to 105 Deg.
Don't know if single speed motors had the wipe angle reduced when the problem of hitting the rubber became apparent.
Your car has the early type wipers.
Seems like you have the wrong blades or arms or both.
Hope this helps
RonR
Hi Ron, thanks for the info, I just measured the wiper blades they are both 9" and the passenger side wiper arm is roughly 9.5" so 1/2" longer than the other which would explain why its hitting the top windscreen rubber, the wiper motor is stamped 66 and is a single speed see the pic
Jenk.
PostPosted: Tue Sep 22, 2015 3:44 pm
so it looks like i need another wiper arm one which is closer to 290mm rather than 295mm... does anyone have one??
Jenk.
PostPosted: Tue Sep 22, 2015 8:34 pm
Old ones wear where they are pinned to the hub. I had a bunch here but have tossed them.
Go buy a new pair from Karcraft or John Smidt, they are pretty cheap.
PostPosted: Tue Sep 22, 2015 10:25 pm
ok will check it out thanks Doc
Jenk.
PostPosted: Sun Sep 04, 2016 8:30 pm
Just reviving an old topic with a new question:
How do you get the blades off the arms?
Going to switch out the black faded blades for some S.Steel ones, and can't work out how to get em off!
Mini-less ... for now
PostPosted: Sun Sep 04, 2016 10:24 pm
12AUW motor came in with the Oz only recessed scuttle panel, 1968 I think.
You can swap or convert it to the round Oz 2 speed one, but it needs an MGB switch to get 2 speeds + auto park.
Wiring diagram for this mod is in this forum, somewhere...
Note that round Rover UK motors are different. So is their wiring.
PostPosted: Mon Sep 05, 2016 6:01 am
Thanks for the reply, maybe I wasn't specific enough / it seemed improbable someone could ask such a silly question.
I'm looking to put one of these on instead of the black ones
http://www.minispares.com/product/Class ... WB219.aspx?
There look to be pins but I don't want to pry anything off if it means I break the arm and have to replace both bits.
Thanks! Hopefully no wiring needed!
PostPosted: Mon Sep 05, 2016 6:15 am
I put Tex ones similar to those on my 1970 car. As the late Oz scuttle panel is different spindle positions to UK I had to bend the arm ends a bit to fit.
PostPosted: Mon Sep 05, 2016 9:34 pm
Ah hopefully they fit.
I sent this pic to minispares and they said it was an unusual attachment.
Where the black 11" blade section joins to the wiper arm at 5 inches.
Is it easy to get the old black blade section off and replace with stainless steel ones? Pry as I might I can't seem to get it.
