It is currently Mon Jul 21, 2025 8:09 pm
PostPosted: Fri Aug 26, 2016 7:41 pm
Just realised I've never seen one of these on a mini. Some wires running somewhere but doesn't seem to do anything. No fog lamps on the car and left and right things don't seem to do anything.
(Ok not sure why it's coming up sideways...)
Mini-less ... for now
PostPosted: Fri Aug 26, 2016 8:16 pm
EXH is to enable the sports exhaust :)
1968 Morris Mini Cooper S
PostPosted: Fri Aug 26, 2016 8:21 pm
Ah so that's why I've been going so slow. Didn't enable sports exhaust.
Wait. Dammit button seems purely decorative. Or broken, cannot depress
PostPosted: Fri Aug 26, 2016 8:50 pm
The EXH button is usually wired up to an extractor fan under the driver's seat.
"Let us remove your "SHORTS"
PostPosted: Fri Aug 26, 2016 9:00 pm
Thanks for the tip
Maybe it's broken, doesn't seem to be a pressable button. Will have to tinker
PostPosted: Fri Aug 26, 2016 9:25 pm
piped to an air vent directed at the passengers face?
PostPosted: Fri Aug 26, 2016 9:40 pm
wow so many useful comments (including me) sometimes its just to easy
sorry for being me
PostPosted: Sat Aug 27, 2016 6:19 am
Solved!
Asked the old owner.
Apparently some kind of dodgy japanese pollution monitoring thing that was connected to the old exhaust.
Now redundant...
Just realised the useful comments went straight over my head. Not enough sleep :(
PostPosted: Sat Aug 27, 2016 8:49 am
Red light on the left *should* be handbrake warning lamp - a local requirement.
PostPosted: Sat Aug 27, 2016 9:03 am
The middle one is the Superman style heat ray that comes out of headlights, good for toasting the back of cars at the lights.
PostPosted: Sat Aug 27, 2016 9:51 am
Left: Handbrake light - this is what Brickworx installed on complied cars.
Chances are if it doesn't work the wiring behind the light or the handbrake switch is to blame.
Middle: Rear fog light switch - the light was removed for compliance but the holes in the rear beaver panel will still be there if I'm correct.
Right: Catalytic converter overheat light. Pretty much pointless.
PostPosted: Sat Aug 27, 2016 3:10 pm
Beauty thanks for the detail. Yep the paperwork said it did go through brickworx so that makes sense. Not much seems to do anything, guess I'll just leave it all connected til a quiet day crops up...
PostPosted: Sat Aug 27, 2016 3:34 pm
I'd still check the wiring as my rover was the same and it didnt work when I got it.
The screw terminals on the back of the light come loose so check it, just in case the lights power source isn't fused.
PostPosted: Sat Aug 27, 2016 4:05 pm
Oh thanks for the tip, I'll definitely have a look behind. Would be good to have it going if it's a simple fix
