It is currently Mon Jul 28, 2025 2:02 am
 Post subject: I just broke my
PostPosted: Tue Aug 23, 2016 9:43 am
drivers side 1/4 window latch. It snapped when I tried to close it fully :( . Assuming I can source another one, does anyone know what is involved in replacing it?
Thanks
Michael
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
 Post subject: Re: I just broke my
PostPosted: Tue Aug 23, 2016 9:48 am
The catch is held to the window frame pivot stud/shaft by a metal pin which is pressed into the latch. You need to remove the pin to remove the catch from the window frame.
RonR
68 build Mk1 Cooper S
PostPosted: Tue Aug 23, 2016 10:03 am
Where is it broken? I have seen NOS levers on eBay for about $160(!!). Yes, they have a pin pressed into the side which sits in a groove on the pivot. A real pain to remove. Other than already stated I don't believe you can buy the levers new.
PostPosted: Tue Aug 23, 2016 12:18 pm
we have 2nd hand 1/4 window assys here (complete) but rubbers are not the best & would need replacing,
otherwise you could buy a 2nd hand one & fit it to your fram/glass assy
Matt
PostPosted: Tue Aug 23, 2016 12:45 pm
A second pair of hands comes in handy when knocking out the pin. Take your time and you'll be fine. Can remember doing this task a long time ago when I replaced the 1/4 vent seal. I did it with the whole assembly off the door
PostPosted: Tue Aug 23, 2016 2:07 pm
Thanks guys. Just picked up the whole assembly 2nd hand, $25, good price I think. Now I have 2 choices, replace the rubber seal (very difficult) on that one and use it (a pain) or, remove the 2 pins and swap the handles over (potentially very difficult). Thinking I'll try and remove the pin on the broken one first and see how I go....
67 Deluxe
Dry suspension
PostPosted: Tue Aug 23, 2016 2:56 pm
Michael
They can be a pain...but some pressure from outside near the latch (to compress the rubber) helps them last...not whilst mobile necessarily :D
Users browsing this forum: Bing [Bot] and 82 guests
