hello,
as my gti van gets closer and closer im looking at finishing my fuel setup next.
im after some advice on a lift pump.
i plan to run, a bosch o44 (already mounted) as a feed to the rail. i need suggestions for a lift pump to fill my surge tank. will a facet electric pump be up to it? i plan on having the return plummed to the surge then the surge returning to the tank, so it will be literally just to keep the fuel level in the surge full!
thanks in advance!
_________________ -jamie- 1963morris 850 1965 solid side van 1994 rover racecar
