It is currently Mon Jul 28, 2025 1:39 am
PostPosted: Tue Aug 16, 2016 5:22 pm
Hi everyone,
The door pin/bush that's in the top Hinge on my drivers door keeps dropping down after a few open and closes of the door (I then need to tap it back up with a hammer).
What's my best option for fixing this? Can you get oversized pins, or will I need a new Hinge, orrrr other suggestions?
James
PostPosted: Tue Aug 16, 2016 5:59 pm
jprior2912 wrote:
Hi everyone,
James
Find another hinge and repin it. Note the 4 hinges are different.
If the pin is falling out and it is right way up (knurl at top) the hinge hole is worn out.
PostPosted: Wed Aug 17, 2016 8:08 am
What the Doc said...or just drill, bush and re-pin the existing hinge...
PostPosted: Wed Aug 17, 2016 8:28 am
Would some form of Loctite product work on that?
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Wed Aug 17, 2016 9:01 am
Sure, IF the holes in the top and bottom are not worn out. James should have shown me on Thursday. The knurl on top end of pin stops it falling out. But I have seen hinges fixed with nut and bolt, or even a broken hss drill bit. :(
PostPosted: Wed Aug 17, 2016 6:12 pm
The Mini King
As Kevin said there are 4 different hinges & you cannot mix the hinge sections
or should I say you should not mix the hinge sections
the hinges are usually stamped UL, LL, UR, LR or they may be numbered
1 & 2 Together 3 & 4 together 5 & 6 together 7 & 8 together
