It is currently Mon Jul 28, 2025 3:22 am
PostPosted: Thu Aug 04, 2016 5:31 pm
simon k wrote:
GundyGuy wrote:
I might try the front shock setup
So has anyone got a pair of top shock mounts to sell
put a wanted ad - they're fitted to all dry suspension cars
I think there is a how-to for it, but basically you just need to buy an 8mm unbrako cap head bolt to go through the top arm
And make a steel bush 9/16" OD x 8mm ID so it fits properly in the shock.
See my how-to thread.
PostPosted: Fri Aug 05, 2016 12:35 am
drmini's how to:
viewtopic.php?f=25&t=12180
Thanks Doc!
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Fri Aug 12, 2016 5:03 pm
Just visited my local Mini Parts Shop here in QLD
Picked up a Pair of top shock mounts and a pair of Std KYB Shocks
They have the steel bush moulded into each end
So i will turn down a 3/8 bolt to suit
1970 MK2 Cooper S
PostPosted: Sat Aug 13, 2016 6:36 am
A question
What is the width of the spacer between the shock and top control arm as i want to make a steel spacer
1970 MK2 Cooper S
PostPosted: Sat Aug 13, 2016 10:49 am
Put flat washers on to get it sitting right, then make a spacer that length.
It is shorter than the dry spacer due to the hydro bump stop bracket on the arm.
You need to drill the bracket out to 8mm also.
PostPosted: Sat Aug 13, 2016 7:25 pm
Front Shock mod is finished
Made the bottom pin out of 4140
So tomorrow will be a test run
Just going to pump up the suspension a little bit before i do
1970 MK2 Cooper S
PostPosted: Sun Aug 14, 2016 4:19 pm
Well i must say this easy to do mod made a world of difference
STD KYB Shocks i used
And its rides like a new car
Before it was a bit bouncy
I recommend this mod to anyone with Hydro Suspension
1970 MK2 Cooper S
PostPosted: Sun Aug 14, 2016 5:30 pm
that's why people have been doing it since 1965 ;)
Users browsing this forum: Bing [Bot] and 92 guests
