It is currently Mon Jul 28, 2025 6:03 am
PostPosted: Thu Jul 28, 2016 9:05 pm
Hi all just got the car running today but my ignition light stays on while it's running what could the problem be?
PostPosted: Thu Jul 28, 2016 9:22 pm
It's not charging. Thats what the light is there to tell you!
PostPosted: Thu Jul 28, 2016 9:39 pm
It's a new alternator and battery
PostPosted: Thu Jul 28, 2016 9:55 pm
Wrong/loose wiring? Run a multimeter across the battery terminal while it's running, that will tell you straight away if alternator is working or not.
PostPosted: Fri Jul 29, 2016 2:55 am
Does the ignition light come one when Key is turned on and stays on after engine is started and running or Light comes on only after engine is started?
"Let us remove your "SHORTS"
PostPosted: Fri Jul 29, 2016 6:22 am
Convertible mini it comes on and stays on when engine is running.
PostPosted: Fri Jul 29, 2016 2:37 pm
your new alternator isn't alternating like it's meant to...
PostPosted: Fri Jul 29, 2016 5:36 pm
...... because its not connected properly???
Cheers, Ian
Users browsing this forum: Bing [Bot], JM1275 and 90 guests
