It is currently Mon Jul 28, 2025 3:48 am
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: At my wits end
PostPosted: Thu Jul 28, 2016 6:58 pm
78Clubbie wrote:
dawi03 wrote:
gtogreen1969 wrote:
Get a multimeter and start tracing the wires and checking them for power.
Also check your earths for continuity.
Will get multimeter, how do i trace wires for power though with multimeter?
Switch multimeter to measure DC volts. Closest setting larger than 12 (Usually 20 or thereabouts)
Make sure the black lead is plugged to black socket on multimeter
Red lead plugged to dc volt red socket. (Check multimeter manual if not sure)
Go to battery. Put black lead/probe on -ve terminal, red on +ve terminal. Should then measure 12 or thereabouts
Now put black lean/probe on the body somewhere (Try where the battery -ve connects to the body) then put red on +ve at battery. Should have same voltage as previously (give or take). If no voltage then battery is not good or connections not good !
Now go to front of car.
Place black probe on one of the engine bolt/studs, then place the red on one of the fuse terminals. (Always good practice to earth first with black, then apply red) If they are live then you will get 12volts or thereabouts. Start by checking the brown wire connection. Then move the red probe to the other side of the fuse, should be the same voltage.
Repeat for the other side. Note that this side is only live if ignition is on.
White is the feed or "delivery" side, Green (Mostly) is downstream supply to things that have power when ignition is on.
Now your marching ! (As they said on Stripes - Look it up !)
Repeat the process using the electrical diagram as a guide, working back to your ignition switch and the wiring to the clocks (Speedo etc).
Hope that helps.
Look up Youtube for auto electrical. Should be lots of good how to's.
Thanks mate I managed to work it out which is fantastic. got the dash lights working!! the water temp and fuel isnt working properly though i think it may be the stabilizer?
Other than that im pretty darn happy i didnt need to call an auto elec and i did it all myself even though it took a few days, but thanks to Ausmini members you got me there hehe. Learning one step at a time!
PostPosted: Fri Jul 29, 2016 10:02 am
Because your headlights are not working i would check the wiring on the new indicator stalk. The headlight power (blue wire) goes to the indicator stalk. It comes out of the stalk as low or high beam. These are also blue wires but have a white or red stripe.
PostPosted: Sat Aug 13, 2016 12:03 pm
Did you manage to get a manual? There are two I recommend, one is the brown haynes manual and the other "black book" workshop manual. I have a few others, but between them, they have more detailed and illustrated approach to things. I find the other revised and newer manuals have left a lot of the diagrams out.
Users browsing this forum: Majestic-12 [Bot] and 82 guests
