It is currently Sun Jul 20, 2025 7:22 am
PostPosted: Sat Jul 23, 2016 8:49 pm
winabbey wrote:
Bill B wrote:
winabbey wrote:
According to the BMC Australia Standards document:
PMZ410 is Recessed Pan-Head Screw Unified, Zinc Plated, 1/4" diam x 5/8" long, UNF 28 tpi
PMZ412 is the same but 3/4" long
What does a "Recessed Pan-Head" look like?
Well, "furgle me nergles"
That is brilliant!
"Pan head" is your standard dome-headed screw with slot drive; "Recessed" means Philips/pozidrive.
Does that also mean that Aust minis had pozidrive fasteners or was that only for UK standards?
Thanks Winabbey
PostPosted: Sat Jul 23, 2016 9:31 pm
Bill B wrote:
... or was that only for UK standards?
BMC Australia adopted the BMC UK set of standards and modified them to suit, where required. That standard didn't need changing so it still says BMC UK in the footer. Other standards can be a specific BMC Australia version. Hydrolastic fluid is an example.
PostPosted: Sun Jul 24, 2016 2:24 pm
gtogreen1969 wrote:
Hows this
sitnlo62 wrote:
David,
Here is a diagram of the way the hinge bolts, studs and washers should be. it is correct!
Note stud length and washer and spacer positions are shown for both upper and lower hinges.
Hope this is of some use to you.
Dave
How much simpler do you need it to be?
This diagram shows exactly how long each screw is, where it goes and the required washers.
I made this drawing years ago while disassembling factory fitted up doors.
OK, its a rough drawing but all the information is there, its not rocket science guys!!!
Dave
PostPosted: Mon Jun 26, 2017 9:46 pm
So for someone starting with bare hinges the studs are 3 different sizes? Also does anyone have dimensions on MYH103 washer that Doug mentioned?
PostPosted: Tue Jun 27, 2017 2:53 pm
It's a flat thin washer, about the thickness of the body metal, and about 40mm diameter from memory. I assume its purpose is to gently spread the load in that area of the door skin by flexing to a certain degree. A thick washer might leave an impression through the door skin when under load and hence be visible from outside.
I'll see if I can get more details in the next day or so as I'm about to dismantle my doors.
PostPosted: Tue Jun 27, 2017 3:25 pm
Known in another industry segment as penny washers.
PostPosted: Tue Jun 27, 2017 4:28 pm
Where on earth do you get penny washers these days?
PostPosted: Tue Jun 27, 2017 4:30 pm
Ask for fender washers?
PostPosted: Tue Jun 27, 2017 4:50 pm
AKA mudguard washers in Aus
https://www.bunnings.com.au/zenith-1-4- ... k_p2420297
Or try the local fastener shop!
PostPosted: Tue Jun 27, 2017 4:54 pm
ROTFL!!
Imperial sizing! Eh? Just like metric star pickets? Gawd. I guess attributes are attributes.
PostPosted: Tue Jun 27, 2017 10:37 pm
Something like these... 38mm diameter, 7mm hole
