It is currently Sat Aug 23, 2025 6:01 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 538, 539, 540, 541, 542, 543, 544 ... 568  Next
PostPosted: Wed Jul 06, 2016 3:35 pm
You have a pm
PostPosted: Sun Jul 10, 2016 5:59 pm
Replaced the front wheel bearing in the Moke. Went together with out to much hassle for once.
:D
PostPosted: Sun Jul 10, 2016 6:08 pm
Taught myself how to weld cant stand hidden bog :(
But i think i need more practice thank god you can grind it flat lmao
Sent from my SM-G935F using Tapatalk
PostPosted: Sun Jul 10, 2016 6:32 pm
Removed the stereo adjusted the carbs. Replace a breather hose
Tighten up the thermostat housing installed on Friday just needed a nip up.
Sorted out an exhaust leak
1968 Morris Mini Cooper S
PostPosted: Tue Jul 12, 2016 5:13 am
Fitted inertia reel lap/sash belts in the back
Fitted lcb headers, catalytic converter and RC40 rear box
Performed exorcism on electrical systems
Evicted grotty Foam sound insulation from firewall
Replaced fuse box
Upgraded headlight wiring, fitted new halogen lights
Fitted high mount rear stop light
Stripped the doors down ready to fit side intrusion bars
Started to pull the front suspension apart to replace bushes, ball joints, swivels, etc
Got myself wedged upside down in the passenger footwell trying to re-attach the switch panel to the lower dash rail
PostPosted: Wed Jul 13, 2016 3:40 pm
I had a front end wheel alignment done this morning after fitting adjustable lower arms and tie bars. It drives really nice now!
PostPosted: Wed Jul 13, 2016 9:06 pm
Trailered the Moke to Readspeed and trailered it home again without an engine. Time for the mid 80's power unit to get a professional freshen up since it still has original pistons and rings.
PostPosted: Mon Jul 18, 2016 12:52 pm
Had fun fitting some MS70s :roll:
....you just lost him his insurance bonus!
997
PostPosted: Tue Jul 19, 2016 6:21 pm
Moved to a different workshop....
PostPosted: Tue Jul 19, 2016 7:02 pm
I've got the Mk2 cylinder over at HM Gem getting a clean up, new exhaust valve guides. New inlets & exhaust valves. Thanks Matt the Miniman for the prompt service in getting the parts up.
Stripped down the gearbox with a bit of difficulty. Ended up making a tool for the 3rd motion bearing, just a semi circle piece of gal pipe. Just need a couple bits need for reassembly. 3-4 outer syncro hub, a new nut for the 1st motion shaft and no shim behind 3rd motion brg retainer. Finance manager has put a hold on purchasing this week.
PostPosted: Wed Jul 20, 2016 6:54 pm
I saw the advert for the twinky head on the forum/eBay and almost bid but decided the freight would be a pain so I looked at gumtree and waddayaknow, there's a k1100 engine for sale in Brisbane. $330 including gearbox, wiring etc.
Couldn't help myself! Another project on the list, maybe.
PostPosted: Wed Jul 20, 2016 7:30 pm
Bought myself a colortune and a carbalancer from Gunson
Just brilliant
I had one carb set to much fuel and the idle set to high on the other.
Really it was only a slight adjustment but good to know I now have it set correctly
PostPosted: Sun Jul 24, 2016 8:21 pm
Got the motor back in, new ring gear works a treat. Also finally got around to cleaning all the Hay motorkhana dirt off.
Dalmeny
PostPosted: Mon Jul 25, 2016 8:07 am
Large dose of shed/hoist envy here :oops: :lol:
PostPosted: Mon Jul 25, 2016 8:23 am
Got my refreshed 1275 motor going again in my 998 Cooper and played with some of the others in the fleet.
1963 997 Morris Cooper
1964 Sunbeam Tiger
1969 Austin 1800
1969 Lancia Fulvia Rallye 1,3S
