I have been having an issue with the left hand side door step. I posted a wanted add for a replacement step sill panel.
viewtopic.php?f=9&t=93011 . I thought I would continue the discussion here.
The original in the car was pretty bad, full of bog and rust so decided to cut it out and replace it with a panel from Mini King. I am actually replacing both the inner sill and outer sill. The issue I have found with the MKO panel is that at point A in the drawing below the Replacement panel measures 4.2mm while the original measures 7.3mm. This gives a wider door gap at the bottom. Seeing at though I am fitting a new outer sill I can lift the outer sill to compensate but we found that the S type chrome moulding will foul the bottom of the door.
There is not enough meat at point B on the panel I have to flatted out the bend and refold it at the correct dimension.
Anybody else had this issue?
I am chasing an original panel from a wreck is somebody has one.....
Ian
