It is currently Mon Jul 28, 2025 9:47 am
PostPosted: Tue Jun 28, 2016 4:56 pm
Hi all,
could you please identify what remote gearbox this is
is it 3spd syncrho or 4spd synchro,
it is 12G1128?
not 22G1128
PostPosted: Tue Jun 28, 2016 6:02 pm
Is their a list of all gearbox casting numbers for the
morris mini remote gearbox
PostPosted: Tue Jun 28, 2016 6:27 pm
Yes there is one in Mini Car Clinic/ Mini King catalog I will post details shortly.
[edit]
These are all remote type:
3 synchro-
22G68- also used on magic wand
22G190
22G333
22A1228
22A1522
4 synchro- these 2 boxes are functionally identical. Used on both remote and puddin' stirrer shifts.
22G1128- most common one here
22G846
Last edited by drmini in aust on Tue Jun 28, 2016 7:28 pm, edited 1 time in total.
PostPosted: Tue Jun 28, 2016 7:27 pm
Had a quick look around and couldn't find the 12G1128.
Here are the lists I usually go off
http://mk1-performance-conversions.co.uk/gearboxes.pdf
viewtopic.php?f=25&t=86659
http://www.7ent.com/pages/transmission-id-pg-49.html
PostPosted: Tue Jun 28, 2016 8:14 pm
I believe the gearbox is from the UK united kingdom(England)
I need to verify if it is
998
0r 4 synchro 1275
I will see if I can get an answer from the person and I
will let you know
PostPosted: Tue Jun 28, 2016 8:16 pm
Have you seen the casting number yourself or was it relayed to you by another person?
PostPosted: Tue Jun 28, 2016 8:23 pm
photos are blurry
and it is what they have stated.
I have sent another message to the person
will find out
PostPosted: Tue Jun 28, 2016 9:19 pm
All these gearbox casings came from UK they were not cast here.
However some gearsets were made here by Borg Warner.
PostPosted: Tue Jun 28, 2016 9:49 pm
Has it got a gear set in it? if has laygear number would identify it
PostPosted: Wed Jun 29, 2016 8:15 am
It is very easy to identify a 4 speed syncro case from a 3 speed syncro case, Numbers are not required to do this.
On a 3 Speed syncro Case the area of the case Directly above the sump plug is FLAT.
On a 4 Speed syncro Case the area of the case Directly above the sump plug has a very obvious RAISED section in the casting.(A LUMP)
There are no exceptions.
Hope this helps someone............
Dave
PostPosted: Wed Jun 29, 2016 11:40 am
Is there a list for UK casting numbers?
there is no gearset inside
PostPosted: Wed Jun 29, 2016 11:51 am
U.K. Numbers are above:
Do you have photographs explaining the difference?
PostPosted: Wed Jun 29, 2016 12:15 pm
Looking at logically. If there is no 12G on the listing, only 22G, a then it appears to be pommie Mk2 4 speed depending on the lay gear.
PostPosted: Wed Jun 29, 2016 2:40 pm
Here are 2 images I grabbed from the net.
Flat
Hump
Users browsing this forum: Barkfast and 86 guests
