It is currently Mon Jul 28, 2025 9:26 am
PostPosted: Sat Jun 25, 2016 6:16 pm
Give Ash some flowers Nick .
Air tool oil for me. My portable AFR gauge says it is about right too for my combination.
PostPosted: Sat Jun 25, 2016 6:27 pm
SU's handbook says its SAE 30.... but observation suggests it doesn't matter much.. Look at the range of stuff people find works for them..
Kev's suggestion of "nothing" is interesting. I can always tell if I've been fiddling with the carbs and forget to replace the oil. Car runs fine but is a B&^*er to start.....
Cheers, Ian
PostPosted: Sat Jun 25, 2016 8:27 pm
I have found that you have to experiment to find the right oil for your carbs.
My S has 1.5 twins and likes 0-40; mini K has1.25 twins and likes 15-50; and like Drmini, it is happy without oil at all!
Totally disagree with the site referred to by Morbo28 about filling to 1/2 inch BELOW piston rod; I did that for 25 years until a friend said to fill to 1/2 inch ABOVE piston rod. Cars now run happily all the time. Oil will drain away over a week or so and needs topping up regularly.
You don't have that problem with fuel injection!
PostPosted: Sat Jun 25, 2016 9:26 pm
mine drains away, but I didn't bother topping it up again... so I guess I'm not using anything
PostPosted: Sat Jun 25, 2016 10:06 pm
Cheers, Ian
Mine was always a bugger to start when cold, damper oil or no oil.
So is miniDave's rally car, so he is now fitting a Weber .
PostPosted: Mon Jun 27, 2016 8:42 am
I've used auto trans fluid in most of my Minis, with exception of my 1100 van. It ran best on 20w50.
I don't think there is a correct answer for what oil to run in SU dampers. Run what works best for that engine.
PostPosted: Mon Jun 27, 2016 12:40 pm
SAE30 engine oil....
the correct ounce weight spring however makes the difference.
....you just lost him his insurance bonus!
997
PostPosted: Mon Jun 27, 2016 4:48 pm
+1. Sort this out first before playing with dashpot oil.
The best method I have found is to have a bore scope pointed down the throat of the carb and then go for a run (my borescope is a USB one and I record the run on my laptop). Don't believe what people / computer programs tell you you need.
PostPosted: Mon Jun 27, 2016 5:27 pm
:D I keep meaning to do that... I bought one of these, but so-far it's only been used for deep nasal and ear hole investigations (ewww!)
http://www.banggood.com/A99-2IN1-720P-2 ... 46380.html
PostPosted: Mon Jun 27, 2016 5:36 pm
It is very useful Simon. I have been helping Tadhg with mine. He has a 1310, big cam, race headers, AEG163 head etc etc etc but with a pair of HS2s. Multiple people told him yellow springs, WinSU told him yellow springs but when I put the borescope down the carbs the yellow springs were only letting the dashpots raise approx 5mm at WOT/redline. After swapping around springs, it actually needed blue springs. The process of finding what damper oil to use and what needles had to start all over again.
PostPosted: Mon Jun 27, 2016 6:07 pm
How often should dashpot oil be replaced
Sent from my SM-G925I using Tapatalk
PostPosted: Mon Jun 27, 2016 7:46 pm
It certainly sounds as if the answer varies from person to person. Everything from no oil through to 50 weight!
1018cc, what should I look out for if I use the bore scope when the engine is running?
Sent from my Nexus 6P using Tapatalk
PostPosted: Mon Jun 27, 2016 8:09 pm
Lots of people use ATF, I buy SAE30 mower oil. Its available anywhere. one day ill buy some proper SU SAE20! I've found light oils to create a hestitation on acceleration.
PostPosted: Tue Jun 28, 2016 7:38 am
You want the damper to be open pretty much all the way at peak horsepower. If you don't know where peak horsepower is, I usually just work towards being fully open at redline. I usually check to see that it is using the entire length of the needle.
PostPosted: Tue Jun 28, 2016 8:18 am
I usually take the whole carby piston assembly out and clean with carby / throttle body cleaner every engine oil change or two. The damper oil gets changed at the same time, obviously.
