It is currently Sun Jun 22, 2025 6:40 am
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Thu Jun 23, 2016 1:29 pm
you can see mine down here, the trigger wheel isn't fitted, but it screws on normally. I machined down a standard mini harmonic balancer and took the centre out of a landrover discovery diesel water pump pulley. I interference fitted it, but it has a couple of little welds on it as well. Been there 35-40,000km
PostPosted: Thu Jun 23, 2016 3:07 pm
Interesting. I already have the factory Rover balancer with multi-vee groove and factory matching water pump pulley. I think it will be easier for me to re-make the trigger wheel than new pulleys.
M
PostPosted: Thu Jun 23, 2016 3:24 pm
ah... yep, if you already have them, definitely easier to make a new wheel. I couldn't get pulleys for a reasonable price so made my own.
PostPosted: Thu Jun 23, 2016 4:56 pm
I still one have Ben's kits still sitting around for a rainy day. Haha!
PostPosted: Thu Jun 23, 2016 8:58 pm
Mokesta do you have a picture of the multi vee pulley, the wheel I make for use with a belt drive cam might work.
4efte powered Clubman
supercharged 998 race car
PostPosted: Thu Jun 23, 2016 10:45 pm
I went to the shed to take some photos.
So the kit (which is excellent) looks like this. Nothing screwed together, just loose:
And the sensor part:
But the poly-vee pulley looks like this:
Here are some quick & dirty dimensions. I will measure properly on the weekend:
So the poly-vee and the V-belt both have their outer edge (closest to the radiator) in the same position. This is at 58mm from the face of the plate that separates the engine from the timing gear. The poly-vee is wider and comes closer to the timing cover. The trigger wheel can't fit in there.
The poly-vee pulley doesn't have the two 'puller' holes that are used to mount the trigger wheel onto the V-belt version.
The poly-vee has an outer cylindrical end that the trigger could be mounted onto. This is a diameter of 106.94mm and a length of about 7.86mm.
If the trigger wheel was changed to a 10mm thick ring it could be mounted over the balancer's cylindrical end. A grub screw could be used through the area of the 'missing tooth' to hold it in place.
The bracket to hold the sensor needs to be changed/spaced to position the sensor for the new wheel location.
I hope this helps.
M
PostPosted: Thu Jun 23, 2016 11:38 pm
what about using the flywheel as trigger carrier? like the factory did with the injection cars and the Verto flywheel.
i haven't seen a non-verto since years, so it may be a stupid idea. but maybe worth a thought
Rover 214 atm ....
PostPosted: Fri Jun 24, 2016 8:25 am
best to get it all on one shop these days
http://trigger-wheels.com/store/contents/en-uk/p98.html
100% Pure A Series Turbo
PostPosted: Fri Jun 24, 2016 7:58 pm
Or you could look on KAD or MED web sites , Have most of what,s wanted, A bit exy but.
16v, twin cam, 'a'series, cooper S replica,3x dcoe webers,Around 200 HP and heaps of torque
PostPosted: Sat Jun 25, 2016 7:41 pm
sorry for some reason i hadn`t spotted this topic (getting old) :-)
but we just machine the pulley
like this-->
ah bugga, cant find the pic
i`ll dig it out & post it here
edit--> found one
we`ve been ddoing it this way for a few years now
we use 36/2 with Adaptronic ECU system
easy-peasy :-)
PostPosted: Sat Jun 25, 2016 7:58 pm
make a small braket to hold your sensor & away you go :-)
PostPosted: Sat Jun 25, 2016 8:03 pm
sorry i don`t have any better pics of it
PostPosted: Mon Jun 27, 2016 8:52 am
Looks a more robust setup than screwing a trigger wheel on.
