It is currently Mon Jul 28, 2025 9:53 am
PostPosted: Sun Jun 19, 2016 8:33 pm
Hi,
I'm putting together my 1962 850 engine and I'm not sure which is the correct thermostat housing to use. The one that came with the engine was considerably lower and squatter compared to another that came in a box of spares. They are both in reasonable shape, but if one is correct for an early 850, then that is the one that I'll put back on the motor.
James
PostPosted: Sun Jun 19, 2016 8:44 pm
not the squatty one.
PostPosted: Sun Jun 19, 2016 9:55 pm
I have seen some early 850's with the flat thermostat housing but the top hose kinks due to the engine height difference.
The angled housing is better suited to the 850 engine.
PostPosted: Sun Jun 19, 2016 10:36 pm
My 61 850 had the flat one when bought in 1964.
PostPosted: Mon Jun 20, 2016 8:52 pm
Thanks for the info, I'll run with the flatter one.
James.
PostPosted: Tue Jun 21, 2016 7:41 am
The flat ones are MG part.
"Let us remove your "SHORTS"
PostPosted: Tue Jun 21, 2016 8:37 am
The high domed one came out sometime after 1963. AFAI remember all Morris 850s and Cooper 997 here had a flat one, whether it is that particular flat one I'm not sure, but I think it is. :)
PostPosted: Tue Jun 21, 2016 3:04 pm
flat one same as sprite
PostPosted: Thu Jun 23, 2016 8:55 am
I have a quantity of 20 or so original Rover Thermostat housings if any one is after any. Yes Genuine Rover from the UK.
