It is currently Fri Jul 25, 2025 10:39 pm
PostPosted: Tue May 31, 2016 8:22 pm
Changing the cones in my clubman and refurbishing as l go, what did a 12/76 use for packing for the subframe to body, the gasket below the locktab on the tower, was it this (see link), minispares parts book says pre 1976, whatever my car has disintegrated a long time ago
http://minikingdomonline.com.au/product ... uspension/
1993 R32 Nissan Skyline GTR
PostPosted: Tue May 31, 2016 9:01 pm
davem wrote:
Changing the cones in my clubman and refurbishing as l go, what did a 12/76 use for packing for the subframe to body, the gasket below the locktab on the tower, was it this (see link), http://minikingdomonline.com.au/product ... uspension/
yes, that's the plate between the subframe and the crossmember, it's a bit confusing why you're referring to the gasket between the locktab and crossmember though
forget the minispares parts book, it'll probably be referring to rubber mounted post '76 subframes
PostPosted: Tue May 31, 2016 9:03 pm
Apologies I meant the gasket under the lock tab, who sells them?
PostPosted: Tue May 31, 2016 10:10 pm
Just buy some gasket material or rubber sheet and cut your own. Quicker than looking for new ones online.
Users browsing this forum: No registered users and 118 guests
