It is currently Fri Jul 04, 2025 10:11 pm
PostPosted: Wed May 08, 2024 1:42 pm
I have designed various 3D printed tools and items to help me out during my Mini restoration and since 3D printers seem ubiquitous, I thought it would be great for the community to have a thread where we can share links. If you have your own, or find any designs that you'd like to share, please post them.
Some of my designs (from my Printables profile https://www.printables.com/@Mearcat/models) :
Door clamp - This tool helps hold the door while fitting/adjusting them. Suits wind-up and sliding window models
https://www.printables.com/model/250164-classic-mini-door-clamp
Panel gap tools - Simple tool for setting car panel & door gaps
https://www.printables.com/model/244897-car-panel-gap-gauge-tool
Rear quarter window sanding block - Sandpaper holder for sanding quarter window post-rust repair
https://www.printables.com/model/696693-classic-mini-rear-quarter-window-sanding-block
Flexible sanding block - for sanding car panels or anything curved
https://www.printables.com/model/505709-flexible-sanding-block
Door hinge templates for aligning hinge holes new A-panels
https://www.printables.com/model/871604-classic-mini-external-door-hinge-templates-for-a-p
-Alan
Report this post
PostPosted: Wed May 08, 2024 2:14 pm
Some others I've found while searching for Classic Mini related prints (I can't of course guarantee that any of these will work, or match your model Mini)
SU HIF44 Air Cleaner Elbow
https://www.thingiverse.com/thing:5733101
Gauge holder allow extra gauges to be added to a Cooper S 3 clock binnacle
https://www.thingiverse.com/thing:5913417
Seat Belt cover
https://www.thingiverse.com/thing:3018522
Centre binnacle extension piece for a tachometer like the old Broadspeed type
https://www.thingiverse.com/thing:4710094
Case for a 12v power adaptor which fits in the ashtray space in the upper dash pad
https://www.thingiverse.com/thing:1638494
Gearbox spring and ball tool for synchronizer assembly
https://www.thingiverse.com/thing:3838125
or
https://www.thingiverse.com/thing:5371649
Gearbox Double Roller Bearing Removal Spacer Tool
https://www.thingiverse.com/thing:3838110
Wheel Bearing Installation Tool - install the outer rings of new wheel bearings for disc type minis
https://www.thingiverse.com/thing:3838122
Clutch Slave Filler - Pre Verto versions
https://www.thingiverse.com/thing:6531954
Sun visor mounting brackets
https://www.thingiverse.com/thing:5324057
Demister vent
https://www.thingiverse.com/thing:5371986
Starter motor plug - magneti marelli pre-engaged starter
https://www.thingiverse.com/thing:4942483
Door lock plinth/surround
https://www.thingiverse.com/thing:4940208
Clutch oil seal tool
https://www.thingiverse.com/thing:4600947
Phone holder (replaces dashpad ashtray)
https://www.thingiverse.com/thing:2203204
LHS heater tube
https://www.thingiverse.com/thing:3969645
CZH628 B-pillar striker blanking cover plate
https://www.thingiverse.com/thing:4680972
123ignition electronic distributor seal
https://www.thingiverse.com/thing:4841962
Cup holder - attaches to front seat bracket
https://www.printables.com/model/480988-classic-mini-cup-holder
Steering column indicator/blinker holder
https://www.printables.com/model/859028-classic-mini-blinker-holder
String method clips for DIY toe check
https://www.printables.com/model/757603-classic-mini-string-method-tracking-front-clips
Grille Grommet for Clubman grille (CZH614)
https://www.thingiverse.com/thing:2526421
-Alan
Report this post
PostPosted: Mon May 13, 2024 4:49 pm
Milatsmadmini
https://www.thingiverse.com/thing:4839919
Dimple die
https://www.thingiverse.com/thing:4225821
HIF44 substack
https://www.thingiverse.com/thing:4658494
HIF44/HS6 velocity stack
https://www.thingiverse.com/thing:6180213
HS2 velocity stack
https://www.thingiverse.com/thing:4609072
Mini/Moke heater vent
https://www.thingiverse.com/thing:3626911
Moke coasters
https://cults3d.com/en/3d-model/various ... -mini-moke
Mini moke keyring :P
https://www.thingiverse.com/thing:4864662
Minilite wheelcap
https://www.thingiverse.com/thing:6307223
Clubby interior door handle surround.
Report this post
PostPosted: Thu May 16, 2024 8:29 pm
Just finished this up tonight.
Its to replace a mark 1 speedo needle.
Guestimate the size from the remains, put it in CAD and printed a negative to be cast in epoxy, since I didn't have any filament in the right color.
Needs a polish but came up well I think.
Report this post
PostPosted: Fri Aug 09, 2024 9:09 am
Here are a couple I've done.
Elbow to fit a standard air filter housing to an HIF44
A little collar to tidy up the end of the air filter housing when the clunky air temperature compensation thing has been thrown away.
https://www.thingiverse.com/thing:5094050
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
Report this post
You can post new topics in this forum
You can reply to topics in this forum
