3D Printing - Designs, Tools and Ideas https://ausmini.com/forums/viewtopic.php?f=65&t=102302 |
Author: | Mearcat [ Wed May 08, 2024 1:42 pm ] |
Post subject: | 3D Printing - Designs, Tools and Ideas |
I have designed various 3D printed tools and items to help me out during my Mini restoration and since 3D printers seem ubiquitous, I thought it would be great for the community to have a thread where we can share links. If you have your own, or find any designs that you'd like to share, please post them. Some of my designs (from my Printables profile https://www.printables.com/@Mearcat/models) : Door clamp - This tool helps hold the door while fitting/adjusting them. Suits wind-up and sliding window models https://www.printables.com/model/250164-classic-mini-door-clamp ![]() Panel gap tools - Simple tool for setting car panel & door gaps https://www.printables.com/model/244897-car-panel-gap-gauge-tool ![]() Rear quarter window sanding block - Sandpaper holder for sanding quarter window post-rust repair https://www.printables.com/model/696693-classic-mini-rear-quarter-window-sanding-block ![]() Flexible sanding block - for sanding car panels or anything curved https://www.printables.com/model/505709-flexible-sanding-block ![]() Door hinge templates for aligning hinge holes new A-panels https://www.printables.com/model/871604-classic-mini-external-door-hinge-templates-for-a-p Attachment: Door Hinge Guides.jpg
Author: | Mearcat [ Wed May 08, 2024 2:14 pm ] |
Post subject: | Re: 3D Printing - Designs, Tools and Ideas |
Some others I've found while searching for Classic Mini related prints (I can't of course guarantee that any of these will work, or match your model Mini) SU HIF44 Air Cleaner Elbow https://www.thingiverse.com/thing:5733101 Gauge holder allow extra gauges to be added to a Cooper S 3 clock binnacle https://www.thingiverse.com/thing:5913417 Seat Belt cover https://www.thingiverse.com/thing:3018522 Centre binnacle extension piece for a tachometer like the old Broadspeed type https://www.thingiverse.com/thing:4710094 Case for a 12v power adaptor which fits in the ashtray space in the upper dash pad https://www.thingiverse.com/thing:1638494 Gearbox spring and ball tool for synchronizer assembly https://www.thingiverse.com/thing:3838125 or https://www.thingiverse.com/thing:5371649 Gearbox Double Roller Bearing Removal Spacer Tool https://www.thingiverse.com/thing:3838110 Wheel Bearing Installation Tool - install the outer rings of new wheel bearings for disc type minis https://www.thingiverse.com/thing:3838122 Clutch Slave Filler - Pre Verto versions https://www.thingiverse.com/thing:6531954 Sun visor mounting brackets https://www.thingiverse.com/thing:5324057 Demister vent https://www.thingiverse.com/thing:5371986 Starter motor plug - magneti marelli pre-engaged starter https://www.thingiverse.com/thing:4942483 Door lock plinth/surround https://www.thingiverse.com/thing:4940208 Clutch oil seal tool https://www.thingiverse.com/thing:4600947 Phone holder (replaces dashpad ashtray) https://www.thingiverse.com/thing:2203204 LHS heater tube https://www.thingiverse.com/thing:3969645 CZH628 B-pillar striker blanking cover plate https://www.thingiverse.com/thing:4680972 123ignition electronic distributor seal https://www.thingiverse.com/thing:4841962 Cup holder - attaches to front seat bracket https://www.printables.com/model/480988-classic-mini-cup-holder Steering column indicator/blinker holder https://www.printables.com/model/859028-classic-mini-blinker-holder String method clips for DIY toe check https://www.printables.com/model/757603-classic-mini-string-method-tracking-front-clips Grille Grommet for Clubman grille (CZH614) https://www.thingiverse.com/thing:2526421 |
Author: | mattsmadmini [ Mon May 13, 2024 4:49 pm ] |
https://www.thingiverse.com/thing:4839919 Dimple die https://www.thingiverse.com/thing:4225821 HIF44 substack https://www.thingiverse.com/thing:4658494 HIF44/HS6 velocity stack https://www.thingiverse.com/thing:6180213 HS2 velocity stack https://www.thingiverse.com/thing:4609072 Mini/Moke heater vent https://www.thingiverse.com/thing:3626911 Moke coasters https://cults3d.com/en/3d-model/various ... -mini-moke Mini moke keyring ![]() https://www.thingiverse.com/thing:4864662 Minilite wheelcap https://www.thingiverse.com/thing:6307223 Clubby interior door handle surround. |
Author: | kirby [ Thu May 16, 2024 8:29 pm ] |
Just finished this up tonight. Its to replace a mark 1 speedo needle. Guestimate the size from the remains, put it in CAD and printed a negative to be cast in epoxy, since I didn't have any filament in the right color. Needs a polish but came up well I think. |
Author: | Timbo [ Fri Aug 09, 2024 9:09 am ] |
Here are a couple I've done. Elbow to fit a standard air filter housing to an HIF44 https://www.thingiverse.com/thing:5733101 ![]() A little collar to tidy up the end of the air filter housing when the clunky air temperature compensation thing has been thrown away. https://www.thingiverse.com/thing:5094050 ![]() Tim |
